Dash wart removal
GT3 player par excellence
I .ike it
Can u ake one for iPhone and iPad?
Here are a few more details on what I did.
As mentioned earlier, the sport chrono is only held into the dash with spring clips. a single connector attaches to the clock.
![](http://s20.postimg.org/my6zkbvsd/Sport_Chrono_Upgrade_1.jpg)
I purchased a new sport chrono housing. Leather covered is around $500. I purchase the non-leather version for about $120.
![](http://s20.postimg.org/r8lnfx0vh/Sport_Chrono_Upgrade_2.jpg)
![](http://s20.postimg.org/kw6i62xt9/Sport_Chrono_Upgrade_3.jpg)
I knew the Solo DL wouldn't just fit. So let the cutting begin.
![](http://s20.postimg.org/k8290voh9/Sport_Chrono_Upgrade_4.jpg)
I drew up a mount for the Solo DL to fit in the Sport Chrono housing, had it fabricated and used some heavy duty automotive body panel adhesive to attach the pieces.
![](http://s20.postimg.org/v8xe5wgq5/Sport_Chrno_DL_Upgrade_01_1.jpg)
I should have stopped right around here; actually I should have stopped one step earlier and not sanded the rubberized coating off of the housing. I think this state would work well.
Of course I took it further and intended to blend the housing contour to the Solo DL a little better. Break out the body filler:
![](http://s20.postimg.org/5enlg4gq5/Sport_Chrono_DL_007_1.jpg)
I don't think this step is necessary. It added a lot of time to the process and didn't majorly improve the aesthetics.
I'll have to go take a photo of the final product, but you get the idea.
I figured out several things that I would do differently if I made another. If there is enough interest, I could look into making more, but it sounds like you all have a variety of different gadgets to be mounted: IPhone, Traqmate, Racelogic, etc.
Thanks for sharing
