Cup splitter
So im trying the cup spliiter for .2GT3..
Am i missing something? There is nothing to line up the holes with. I was gonna use zip tie to just hold them together with the plastic fender parts...
![](https://lh6.googleusercontent.com/-ff0rzvDEh_Y/UTFhVX6wEnI/AAAAAAAAAuk/FhrlGsYE4uQ/s649/20130301_181508.jpg)
![](https://lh6.googleusercontent.com/-WUSB5HV8gZA/UTFhXvSPOiI/AAAAAAAAAus/B-lpNZykmbI/s865/20130301_181514.jpg)
Thank you. I thought I was missing some plastic stuff...
ll play with it and zip tie them =)
I personally like the material of cup splitter ver OEM (stiff)
I have a small plastic piece that hangs down from the back of the bumper cover, but I don't see it in your pic. I made a small hole in that and put a plastic push fastener through the hole in your pic and into the plastic piece. It bends the lip inward very slightly, but gets the job done. I'll get a pic to better explain myself though.
Not sure if this is true but what if gen 2 cup splitter is as flexible as gen 1. Wouldnt it be better for durability since if flexes a lot more? I think gen 1 is like fruit rollup soft. But maybe stiffer material deflects higher wind speed and generates more down force....
Anyhow, I am loving the cup splitter =)
I feel like something should be here... maybe it went missing when I "lost" the OEM piece at the track =)
The hole doesnt even line up with anything. Just hangs down.
![Name: Capture.JPG
Size: 51.5 KB](https://rennlist.com/forums/attachments/997-gt2-gt3-forum/707680d1362209741-cup-splitter-capture.jpg)
They are just like the rocker panels. you're supposed to kick them every time you walk around the car ;-)
Orbit made me some brackets and added the fender gurneys and everything was real solid, but now i just kick them. on the track no problemnever had one come out at the end more than 5mm but if i scrape real bad so that the whole lip rolls under tha car sometimes the end pops out..This rarely happens in flatland Florida.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
