24k mile service for the GT3 part 1 and 2 >>
Bought the parts from suncoast. Quick shipping, good seller. I think they may have left out the small rubber o-ring for the oil filter, so I left the old one in (it was in good shape).
24k service is something like this:
+ plugs (going to tackle this tomorrow)
+ oil filter / oil change
+ air filter
+ cabin filter
+ wiper blades and fluid
Parts...
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_00.jpg)
Out with the old. What a mess. The lift, however, was a real back and time saver. Should have bought one sooner. Now I just need to sink it into the concrete.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_01.jpg)
I had the car lower when I first pulled the case plugs, but it comes out pretty good. No way around getting splashed. This might be a shock to you west coast folks, but this is dirt and grime. Come spring I'll get under there and power wash and degrease.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_02.jpg)
Cheap oil filter wrench that fit great. No need for the $40 porsche part. As others have mentioned, loosen the oil filter cap a bit before warming the car up and draining the oil. This allows most of the oil to drain from the filter with little clean-up. Plus it makes it much easier to unscrew the cap once the engine is to temp.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_03.jpg)
Old and busted...
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_04.jpg)
...new hotness
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_05.jpg)
Air filter housing out to do the filter swap.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_06.jpg)
I figured it wouldn't hurt to hit the throttle body with some carb cleaner.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_07.jpg)
Sprayed a little electronics cleaner on the MAF sensor as well.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_08.jpg)
old and busted... new hotness.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_09.jpg)
The car took about 9.25 quarts of oil in the end. Manual says 9.25-9.5, but other DIYs have stated around 8 quarts. I really can't stand the electronic level oil gauge. I find it to be inaccurate and erratic. Sometimes I will get an oil level warning, usually after coming to rest at a stop light after normal driving. If I check it again in 2 minutes it shows full. Some days it shows low. At least now I know I'm starting with 9 quarts.
More to come tomorrow.
+ air filter
+ cabin filter
Parts...
Old and busted...
...new hotness
GT3 player par excellence
u got to b kidding
these cars are only good for 25000 miles.
u should sell cheap to me
seriously that's a great lift
when u sink into concrete hw many inches u have to cut?
Here's a helpful thread on dimensions of this lift for that very purpose.
According to the bendpak site: Lowered height: 4-3/4"
Leave it to a the vette guys:
![](http://i131.photobucket.com/albums/p287/funnone/0529071005a.jpg)
![](http://i131.photobucket.com/albums/p287/funnone/0602070958a.jpg)
thx
that's a nice clean install
another q is that most slabs are 4", almost never more than 6"
if 3.5-4" is cut in, wouldn't the remaining 2" or so crack under wt?
...24k mile service for the GT3 part 2:
I loosely followed this write up for the spark plug change, but found slight differences in the 997 model.
tools I wound up using:
3/8 ratchet (prefered flex-head)
6" extension
spark plug socket
50mm torx (coil pack bolts)
8mm Socket (heat shield bolts)
magnetic pick-up tool (passenger side aft)
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_10.jpg)
There seems to be more room on the 997. The drivers side was easier because the cat placement makes it a lot tighter on the passenger side (especially for the rear plug).
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_11.jpg)
No blood yet.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_12.jpg)
Plugs are not too bad, but it was time.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_13.jpg)
I usually put a tiny bit of anti-seize on spark plug threads.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_14.jpg)
Thumbs up from the little boy.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_15.jpg)
Started right up. Cleared the service reminder with the durmetric. Now we just have to wait for all this damn snow to **** off!
6" extension
spark plug socket
No blood yet.
![](http://www.squarewave.com/army/andrew/gt3/gt3_24k_service/24k_16.jpg)
Man, you are really going to town. Thanks for the post. I just purchased the oil filter wrench. Thanks again for the detail.
