FS: 2010 GT3 CDN Spec with 5 Lug Conversion ... and a whole lot more!
See the classifieds..............
https://rennlist.com/forums/vehicle-...l#post10183989
Cheers!
Doug N.
PS. Note that the base price of a US GT3 was $112,000, while in Canada it was $138,000.
Cheers!
Doug N.
Car is gorgeous, set-up right and meticulously maintained, I've driven it. Seller would be as good as you could ever hope to deal with when buying a car. Someone seeking a Canadian spec GT3 has the perfect opportunity here.
Thank you for the endorsement SAVYBOY.....how much do I owe you? ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
......Interestingly, Pete loved the slightly stiffer GMG sway bar set up and the super firm and tactile brake pedal associated with the StopTech STR brake set up.
Thanks Ed!
Yes, Tom you are absolutely correct. I will try until Feb 18th to sell it whole, after that it is as follows:
First, Brakes, suspension, front lift kit, and 5-lug come off first, as it can all be done at once
Then the exhaust can be done last, if necessary.
$122,500? That's a crazy price but then again, I don't know what the Canadian's got that we didn't... I didn't pay this much for mine "NEW", loaded in 2011.... Maybe time to sell to beat the Geneva Motorshow....
Doug's car is well sorted with lots of track goodies, good deal for Canadian market.
GLWS, I'll pass the word on to others.
Id leave the front lift and 5 lugs on due to the time involved to remove wheras everything else can come off quick and are easy sell.
If you do remove the 5 lug id say alot of people would be interested in buying the 5 lug set up from you.
