3.8 vs 3.6 reliability
Mine must be outside of it, at 23,000 miles it hasnt went boom
Your question/concern is correct. However, one should not overestimate it. Knowing quite a few GT2, GT3RS etc owners..and owning myself a 3.8 and a GT2 997 - and having owned also a 3.6 GT3..I can tell you from my experience..
1) 3.6 997 are very solid engines..no real problem..even with tracking. However, HP seems to be just at 410 max however..
2) 3.8 997 had also no real issues..even when tracking, but some had variocam issues (sensors goen nuts) that the 3.6 didnt have. Its also said that pistons and "cylinder" are better/stronger in the 3.8 than in the 3.6 as in the 3.8 these are running in a steel hose. However, I have heard from tuners that every 3.8 at least develops 440HP..so this is good news - like that it runs 100rpm more before redline.
3) The problems were - if - on the 3.8RS. What happened here is that sometimes a screw from the air intake valve unit, got loose and got sucked into the engine. This part came from Bosch if I remember correctly. Furthermore, 3.8RS had some issues with the light weight battery..(sometimes exploding)..and exhausts. But again, these case are limited..and as NJ-GT said already..they only seem to affect 3.8RS. 3.6 and 3.8 seem to be rock solid. Speaking therefore of "time bomb" when it comes to any 997 GT3 is too much guys. Any 996 or standard 997 are much more a time bomb then GT3 or GT2. There are 996 turbos out there-..with 500HP and 200,000km (with track use) and they are still running perfectly. I doubt you could find this anywhere else.
For me the 996,997 GT2/GT3 engines are the best engines build -EVER - because their failure rate despite a few cases is so ridicoulously low. Around 70% of these cars are tracked..dont forget that. That rate is probably somewhere close to 20% for ferrari..and even less for Lamborghini..and their failure rate of brake issues - or any other little gremlins is much higher. My GT2 will beat any 458 on the race track,..even if I turn 10 seconds slower per lap..after 40min the Maranello horse will have to stop anyway..
Ah, write me a PM..I live where you live..we could go for one of these Belgian..
Hey Joris,
I wouldn't want to hard track either motor outside of warranty coverage. Which one is more reliable? I don't know but what I do know is they are both too expensive to fix. CPO or buying the extended warranty coverage is the only way to look at it IMO. How is the Cup search going?
My opinion on this is that if it were the case I would have read about it on rennlist, considering the amount of trackdays some of you guys do + you also know lots of people running GT3 cars on track so word would spread quickly.
Hey Joris,
Rumor has it one of teh torque settings in the RS3.8 was wrong during a period of production......cars built during that time go boom. Rad is correct, the low mile garage queens are russian roulette when they come out of warranty. If a car has this porblem, after afew weekends atthe track they detonate
Really ?
How many street driven 3.8RS have gone kaboom ?
wsh
Well, it's just because I hear this story coming from a Porsche dealer with a lot of clients that track. Then again the mechanics in another dealership say it is not true. The reason I ask is because I sold my 3.8 and the guy who bought it is also selling it (don't ask me why) and he had a potential buyer that in the end didn't buy the car because he checked around and he found out that the 3.8 is a lot less reliable than the 3.6 when used on the race track.
Will do![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Will do
well, I dont believe this either - the 3.8 has no problems. There are 30-40 3.8s running in the Porshe sports cup series..just check the results..and you will see how many are 3.8s. I even know people driving there with 3.8..no issue at all.
Here is the link to the Porsche series Im talking about:
http://www.porsche.com/porschesports...currentseason/
The 3.8s that get tracked and with aggressive downshifts/gearing down have a very nasty issue with cam adjusters coming apart. Bad design
Brian Himmelman (07-21-2023)
