Can I charge battery by leaving car run
I have a set of Hoosiers on my car.
My 2010 GT3 is sitting on my trailer at my warehouse. I don't want to put the street tires on and drive the car home.
I have a autocross next weekend that I might attend.
I don't use a trickle charger.
Can I charge the battery by just letting the car run at idle in neutral for like 20 minutes ?
Is this bad ?
Will it work ? Or do I need to drive it for 10-20 miles and put a load on the car ?
Thanks,
Lehman
PS...I would have asked Rad when I saw him 2 days ago but I didn't realize I would be lazy and not want to swap wheels back and forth.
Is this bad ?
Thanks,
Lehman
Car is currently sitting on trailer with Hoosier on.
I think I can get another autocross out of the tires that I have on the car. I have multiple sets of tires and wheels. Some sticker sets, which I don't want to use for a local event, and am saving my stickers for national autocross competition.
Since the event is next week, and the car is already on the trailer.....I don't want to take the time and energy to change to street tires.....drive the car, and then before the competition put the Hoosiers back on and then put the car back on the trailer.
And since I don't use a trickle charger...I was thinking I could just run the car while on my trailer for like 20 minutes (I will unhook the rear straps as I don't want them to get to hot from the muffler etc.
It will charge but you need to raise the rpm over 1500rpm just briefly to load the regulator otherwise there's a chance it will sit not charging.
Its certainly not the best way.
Cheers
Jay
Cheers
Jay
If the car will starts, no need to charge the battery...Unless you expect the battery to discharge completely before your next engine start?
To charge the battery fully you need 20-30 minutes.
I would advise to just buy a trickle charger, it's probably a lot easier than taking the car off trailers, driving around, and putting car back on trailer.
