CL Failures - Any Known RS Failures?
As far as I know, the only CL failures to date have all been on non-RS cars. Can anyone verify a failure on an RS?
I've got an RS, hence my concern.
Not that I know of. My understanding is that the parts are the same. However, the wheel size and offset is different, so it does make me pay attention to the theory posited on Geoff's thread that perhaps this has to do with loads and forces. There might be enough leverage in the non-RS design to cause higher stresses than the RS design. Can someone who knows the offsets and such chime in here?
I don't mean to derail my own thread, though. Please keep commenting about any known RS failures!
Did you mean to say all CL failures occurred on RS's? I have yet to see a non RS fail. All failures on here and linked videos have all been on RS's....
I'm on my iPhone now, but when I get home I'll post links.
997.2 Turbo S, GTS, GT3 and GT3RS all have the same Center Lock system.
Lar, if you're asking about catastrophic failure, then no. Problems? Sure.
The wheel hub and CL mechanism is COMMON to all Gen 2 GTx cars down to the part numbers. The same issues that befell various unlucky GT3 owners can happen to us. You wouldn't expect otherwise given the fact pattern.
I would reason that CLs are safe in a laboratory setting where every wheel change is done to the tee as per the factory instructions. I thank the many contributors on this forum for sharing those procedures. Porsche should've done that from day 1 and not leaned on us customers as their guinea pigs.
In the real world, the inner wheel hub threads are probably very sensitive to over-torquing. After hundreds of wheel change into my ownership experience, there is simply no way to ensure EVERY SINGLE change was done with clinical precision. I am already OCD-level hands-on with my car in the pits but sometimes you just have to rely on others to do the job. And I'm genuinely seeing worrisome signs in the other thread I started two weeks ago.
There is no reason to be unduly paranoid, but knowing the latent issues with centerlocks it pays to be extra vigilant. Follow the inspection program every time your wheels come off. Replace worn hubs (even potentially worn ones) prematurely for peace of mind.
Maybe RS owners follow instructions better?
