Suspension Changes - Your Thoughts?
Mostly. It is the entire engine/tranny moving. I have the same problems with the Cayman.
So, a stiffer tranny mount + stiffer engine mounts + Cup Shifter Cables: problem gone. Just avoid the Cup tranny mount, the interior sound (grinding) is extremely loud. I think the PDEM are a gizmo and they are not as stiff as a proper stiff static engine mount. Chat with Eddie, Wevo and TS have some nice stuff for trakcar 1.1.
Just adding a stiffer transmission mount doesn't fix the problem.
WEVO's seem to work great, I prefer a static stiffness...for the same reasons I prefer linear springs.
Urethane is great, but once you start putting in solid (metal) subframe, engine, and tranny mounts, go ahead and kiss all streetability goodbye. The M3 never sees the street...
BTW a while ago there's talk that PDEM is prone to failing on 997.2 cars. Is there any objective way of testing their functionality?
IMO, sways are the last things to fiddle with when setting up a suspension. They affect the transition of load from weighted to unweighted wheel, and vice versa. If you just want a flatter car on turn in & in corners, consider upping spring rates, presuming the dampers are appropriately valved.
Here. Tried the cup transmission mount for one week and promptly had it removed. NVH so bad that I practically feared that the vibrations may tear the car apart. It was a fun exercise...
Mvez this mount gets stressed than you think. Urethane is tough but has lower stress/fatigue tolerance than metal. U sure u want the whole tranny+engine mass to be attached by a piece of plastic? When I had the solid mount I was told the cup cars replaced the part with every transmission rebuild...
Cool idea! Video coming your way soon...
http://www.torquesolution.com/product-p/ts-por-006.htmInteresting. When my tranny comes out for a re-gear, I might look into this. Urethane tranny mounts on my M3 worked nicely.
FWIW, the Carrera Cup Asia Series which runs all the relevant tracks here (Zhuhai, Ordos, Sepang) disallows spring changes. Which takes away the teams' incentives to experiment and build that requisite knowledge base...
So in short, springs and shocks have to stay stock out of practical consideration.
I'm prodding Alex @ SW to figure out an RS 4.0 "upgrade" pack for those of us not wealthy enough to buy anything other than the dive planes!
Only on the highway. We get stretches of real good, autobahn-like multi-lanes around here and can take occasionally take our cars above 300khm (190 old school). Above 220-240 the car used to exhibit a bit of lightness with its nose. With the dive planes it's planted all the way.
On track? Not feeling any difference to be honest. I think it'll take Walter Rohrl or somebody his league to articulate the improvement if any...
Crap...I had Orbit make up some adjustable sways for the "lowly wanna be" aero beetle GTS. I have the so called crappy Sport PASM stock shocks/springs and couldn't afford $4-5k in new coil overs and I wanted to tame some of the body lean and have adjustable sways. I guess I'm just wasting money....
Not having adjustable ARB in my Fiat has been the biggest downside of sharing the car for autoX and track.
At 125 mph, per independent wind tunnel test (Sport Auto in Germany), the dive planes add 6.6 lbs of front downforce, and the 4.0 end plates and new wing angle add 20 lbs.
IMHO, the gains are insignificant. There are more gains from a gurney lip and reducing ride height.
Adjustable ARB are never a waste of money, the allow you to balance the car for different tire sizes, older vs newer tires on a given axle, tight tracks, open tracks.
What Rad said.
Peter
