997 GT2/GT3 Forum 2005-2012
PFC Rotors: Just installed on my .1 (info and p/n's)
Old 06-13-2012, 03:39 PM
Izzone
Izzone's Avatar
Originally Posted by Doc GTO
Ok, what do I need for my 07 Turbo for the fronts?
I have a spreadsheet I will look
icount23 (02-09-2024)
Old 06-13-2012, 04:30 PM
Doc GTO
Doc GTO's Avatar
You keep it with you on the golf course! You are the man!!!
Old 06-13-2012, 11:46 PM
Carrera51
Carrera51's Avatar
Doc GTO:
For your 997 Turbo you need the following:
Hats: 219.157.273.13 PFC V2 Porsche Turbo all wheel drive front hat
Rotors: Slotted-378.32.0060.45 Left front, and 378.32.0060.46 Right Front
Or Dimpled: 379.34.0066.85 Left Front , 379.34.0066.86 Right Front
If I can be of further assistance, please PM me at your convenience.
Kind regards,
Old 09-14-2013, 11:54 AM
Speeds5
Speeds5's Avatar
Figured it out... https://rennlist.com/forums/997-gt2-...clunk-diy.html
Randy or anyone else, can someone explain how does the bevel washer prevents the rotor from floating. If I'm looking at the design properly and understanding correctly the bevel/belleville washer goes in between the hat and the hold down ring. Therefore it creates even more space between the hat and the ring, which I would assume creates even more space for the rotor to float/clunk.
I'm having a hard visualizing how that would stop the floating. I have washers sitting in my garage and contemplating putting them in but wanted to check before doing so. By the way I'm talking about the V2 slotted rotors, not the V1/direct drive ones which use the bobbins.
Eugene
For what it is worth I run the slotted. I have been through two sets of front rotors and never cracked one. Just run them until the slots disappear. I run my pads until they hit backing plate.
Reter had dimpled on his car for the first set (he now runs slotted). The rotor cracked all the way through before the dimples were gone.
I believe the dimpled is more of a street version, slotted more of the track version.......this is what a PFC engineer told me at PRI. For 997.2 GT3 the dimpled and slotted fit in this hat. The dimpled takes a larger pad, since swept area is slightly larger
For .2 cars slotted and diimpled use the same hat. If you remove the bevel washer it is a floating, if you keep the bevel washer in it prevents them from floating
PFC makes a rear brake hat (works with parking brake), but only sells it with a dimpled rotor....not seperate. So I stick with 997.2 turbo rotor
If anyone is wondering why my hat is gold......Reter and I had the two prototype PFC hats from Orbit
Old 12-11-2014, 03:12 PM
obsessedone
obsessedone's Avatar
OK so a couple years later what's the experience with PFC slotted race rotors? How many track days (TD) are you getting out of the rotors? How long have the hats held up? Still using them?
My StopTech rotors were good for 24-30 TD but a couple times hats were shot when rotors were shot so needed full replacement. The cheap ATE rotors came in at hefty 26.5 lbs but lasted 50 TD DE and 28 TD with mix of DE and race. Considering PFC or AP for next season to reduce weight.
Appreciate any further input based on your experience. Thanks.
Old 12-11-2014, 04:10 PM
audipwr1
audipwr1's Avatar
I stop eating candy for 2 days and use the 90 dollar heavy rotors which outlast all the fancy ones
Old 12-11-2014, 05:25 PM
LVDell
LVDell's Avatar
Sorry I can't help as I moved to GiroDisc. I really like the PFC setup but there are 2 reasons I switched to Giro:
1. The inability to use stock pads for street driving on the PFC
2. The lack of a rear setup as they do not have a hat that will clear the e-brake. Sorry but I'm not giving up my ebrake on a street car.
I took my PFC set off and now they just sit in the garage as very expensive paperweight
Old 12-11-2014, 05:53 PM
obsessedone
LVDell, thanks for the feedback. Any chance you weighed the Giros?
Old 12-11-2014, 06:00 PM
LVDell
LVDell's Avatar
Yup, see attached!
Old 12-11-2014, 09:26 PM
obsessedone
So a bit heavier than the AP and PFC rotors but not much. My ATEs weighed 26.3 after 28 track days - didn't weigh them new.
Old 12-14-2014, 08:56 AM
LVDell
LVDell's Avatar
Correct, it appears that the Giros are ~ 1/2 pound heavier than PFC.
Quick Reply: PFC Rotors: Just installed on my .1 (info and p/n's)
