High impact torque wrench for centerlocks?
Has anyone used one of these for the centerlocks? Seems like you could loosen with a breaker bar followed by one of these for removal. You cold retorque with this up to 525 ft lbs and then use a hand operated to get the rest of the way. Not worth it given that it doesn't torque to 600ft lbs?
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Oops- yes it should be enough torque at 440 ft lbs (600nm). My bad! In that case it could replace the breaker bar and the torque wrench. Wonder if anyone has tried this? I think accuracy would be good.
GT3 player par excellence
the nut is ALUM i think.
so the impact gun will kill the alum CL thing in no time.
