Can smog inspection cause check engine light to come on
I just took my car in for smog inspection. At the end of testing he said check engine light came on, and he could not pass. It passed all other areas. Its an 08 gt2. Light has never been on before. Could he have done something to cause this with the sensor he puts up exhaust during testing?
Hmmmm
I would get the light cleared, put a couple hundred miles on it and show up hot for a retest
You know the cats are in good shape I presume.
If they simply plug into your obd port, not sure how they could cause it
Here in lovely Seattle my ex 996-3 passed the joke emissions test with no cats - they simply plug in and verify there are no cel or emission codes...
How many miles logged on high flow cats prior to smog? Are they the 100 or 200 cell type cats?If just put in- Steady state cruising can cause cel to trigger on hi flow cats. Mike
Mine threw a CEL on the smog rollers because it freaks out the PSM. Passes then had dealer clear. If you were on the rollers could just be that.
My son came over and read code for me. P0503. This reads the signal sent by the vehicle speed sensor to ECM is to high or intermittent. The check engine light came on at very end of test. I think what he did was turn off his equipment before shutting car off. This caused a intermittent signal, followed by engine light. Thanks everyone. Someone ask a roofing question so I can contribute
