997 GT2/GT3 Forum 2005-2012
Manual Hood Release on the .1 models?
Old 04-27-2012, 10:28 AM
deputydog95
deputydog95's Avatar
Default Manual Hood Release on the .1 models?
Where is it? I don't have my manual and I can't find anything online about my specific model. Seems like Porsche put the cables in different spots for different models for whatever reason.
Old 04-27-2012, 10:37 AM
NorthVan
NorthVan's Avatar
Is your battery dead?
Old 04-27-2012, 10:50 AM
911SLOW
Admin
911SLOW's Avatar
http://www.porsche.com/all/media/pdf...l_GT3_PCNA.pdf
page 210
Old 04-27-2012, 11:21 AM
deputydog95
Thank you for the link. Unfortunately I don't think they put it in the manual. Page 210 is as close as I could find and that just relates to using a secondary battery.
I guess I'll have to ask the dealer.
Old 04-27-2012, 11:51 AM
911SLOW
Admin
911SLOW's Avatar
You don't care about opening the lid, you just want to know!
Fine I'll play.. : )
You were probably thinking 996.. pulling the steel emergency cable hiding under the headlight?
I checked the workshop manual and can't find it for the 7 there.
But... here is a drawing, showing the position of the servo motor for front lid release, and as far as I can tell, the emergency operation bowden cable is located under the left wheel housing liner. (look arrow A_)
You will have to remove the wheel and then remove the liner to access it
Old 04-27-2012, 12:08 PM
deputydog95
No, I really do care and thank you for playing
Was considering something a little lighter in the battery department and I want to make sure I can get back into the trunk if it shuts itself down on me as it has a LVC circuit.
That looks like a lot of work to get to it. I wonder if I can extend the cable to make it a little easier?
Judging by the pic, do you think it might be easier to just pop the headlight out for access?
Old 04-27-2012, 12:18 PM
911SLOW
Admin
911SLOW's Avatar
I have a Li-ion one with a low voltage cut-off switch.
I have the manual switch in the cabin.
Headlight removal needs access and I don't think you can reach the cable like that .
FWIW the factory's emergency operation, using a secondary power source and feeding the fuse (directly to the lid motor switch) should open it even if the battery is disconnected or completely dead. We need to try this though. Leave the front lid open, remove the negative and try the emergency procedure..
Old 04-27-2012, 12:22 PM
996FLT6
996FLT6's Avatar
U can pop a hood with dead battery. Well at least with the 996. Mike
Old 04-27-2012, 12:26 PM
deputydog95
Mine comes with a switch too, but seems like a pita running that cable through the firewall for the occasional use. I'd prefer to just pop the hood if possible and hit the button the battery.
I saw it done at Sebring recently on a .2, but they had everything torn apart trying to find the cable so I'm not sure exactly how they got to it. It was def on the driver's side.
Old 04-27-2012, 12:28 PM
P.J.S.
P.J.S.'s Avatar
jumping the fuse box on a dead 997.1 works... have done it
Old 04-27-2012, 12:30 PM
deputydog95
I've done it too. It def works. I used to have a B&D jump box till my wife threw away my power cord for it. It worked perfectly for opening the trunk with a dead battery. Maybe I'll just get another box and keep it in the trailer. I tried to get a new power cord for several months and gave up.
Old 04-27-2012, 12:51 PM
Izzone
Izzone's Avatar
credit card, pop out front turn signal
pull cord
easy
Old 04-27-2012, 01:21 PM
deputydog95
pull cord
easy
What's the procedure for that? Where exactly do you need to put the card to loosen the signal?
Old 04-27-2012, 01:54 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,597 Likes on 739 Posts
No you get Randy promise much beer and he'll do it.
Old 04-27-2012, 02:06 PM
mobonic
mobonic's Avatar
the card should be in your manual, and its not the signal its the fog light that you can use the card for.
Quick Reply: Manual Hood Release on the .1 models?
