Engine In Car LWF Install
Does anyone know the installation torque for the four M10 nuts that attach the transmission to the engine on a 997.2 GT3? I think it is 33 ft-lb, but I would like to be certain of this.
I just installed the 996 LWF and 4.0RS pp and disc with the engine in the car. There is a summary of the procedure in 6speedonline posted by iaporschedoc 2-16-09 on the this for those interested.
Thanks.
Thanks.
Thanks John. My 996 Carrera shop manual shows the same figures, but does not address the GT3. I thought the GT3 figures might be higher as the 997.2 GT3 has only four M10 nuts holding the trans to the engine.
As to the 6speed refernce, I couldn't find anything on clutch replacement engine in car in RL.
Thad
Thad
Admin
These are the values for installing the transmission in the 2010+ GT3 /GT3RS / 4L
Release lever shaft Tightening torque 10 Nm (7.5 ftlb.)
Air cowl 3 hexagon-head bolts Tightening torque 10 Nm (7.5 ftlb.)
Transmission stud nuts to body Tightening torque 65 Nm (48 ftlb.)
Engine mounting Tightening torque 85 Nm (63 ftlb.)
Threaded joint securing engine to transmission Tightening torque 45 Nm (33 ftlb.)
Gear support Tightening torque 65 Nm (48 ftlb.)
Vacuum line bracket Tightening torque 10 Nm (7.5 ftlb.)
Drive shaft to transmission Fine thread! Tightening torque 90 Nm (67 ftlb.)
Holder for coolant hoses Tightening torque 10 Nm (7.5 ftlb.)
Transverse strut Important: Do not grease threaded connections in Dacromet finish - aluminium colour Tightening torque 110 Nm (81.5 ftlb.)
Cross member Tightening torque 110 Nm (81.5 ftlb.)
Diagonal brace, M10 Important: This was changed to M12 x 1.5 in the current model year Tightening torque 65 Nm (48 ftlb.)
Diagonal strut, M12 Important: Do not grease threaded connections in Dacromet finish - aluminium colour. Tightening torque 110 Nm (81 ftlb.)
Anti-roll bar, M8 screw Tightening torque 23 Nm (17 ftlb.)
Anti-roll bar, M10 collar nut Tightening torque 65 Nm (48 ftlb.)
