CAE Shifter
#31
Former Vendor
http://www.hardmotorsport.com/CAE-Sh...0014-10014.htm
It is hands down the best Hpattern shifter on the market! The height is perfect, right next to the steering wheel where you want it. It shifts very precise every time and also has a reverse lock out.
#32
Soon going to be part of the Completely Stock DE Class non-mod list
Q) What is that?
A) It is my OE shifter
Q) No it isn't?
A) You are mistaken, I just removed the shifter boot
Q) Isn't it too tall to be the OE shifter?
A) No, I just lowered my seat because I'm tall - it just looks high
Q) Aren't you 5'6"?
A) I have a long torso
Ok, you can run in the Stock DE Class
Q) What is that?
Q) No it isn't?
Q) Aren't you 5'6"?
#33
And because of the shifter's additional springs, it is very close to the feel of a sequential. What I mean is that, with many shifts (2 to 3, 5 to 4, for instance), you 'almost' just pull back or push forward on the stick.
#34
You running with the OE or cup cable?
Also, if cup, how is the sound?
#35
It looks like a very nice product, but $1100 for a shifter seems a bit steep when the OEM one isn't exactly horrible.
My biggest issue was motor movement slop, which I corrected with semi solid mounts. I still do the occasionally dummy shift from 4th to 5th, when I was looking for 3rd
#38
Sound is very much a matter of personal preference: I don't mind the mechanical sounds, but am partial to a quieter exhaust. I find my Fabspeed nice and "quiet". But YMMV.
Paul, you're welcome to take the car out for a few laps next time we connect.
#40
The only mis-shift that I ever used to do with my cup setup, was going from 5th to 6th, when I was looking for 4th. And man was that confusing.
Hasn't happened since the shifter.
#41
If someone could make a nice shifter boot that made it look more OEM I would do this. I just installed the 6 shifter cable and have now street driven it a few times and it seems fine - tiny bit more noise but not a big deal - I was worried it was going to sound like a cupcar with straight cut gears - it does not - but the combo of a lwfw and the 6 cable does slightly incease the rattle noise at idle / very low rpms but it is only very slight increase with the 6 cable.
If I did enough track days like many on this board, I would definitely install this shifter. The only negative I can see with this shifter is that I can see a potential money shift problem if you are looking to do a 4th to 5th shift and the springs sort of prevent the push right and your brain shuts down for a second you may find 3rd?
#44
As I said earlier, the only one that I did (until I realized that I had to be careful) was to go back to 4th from 5th, when looking for 6th, because of not putting enough pressure toward the right. But this was on the highway, not on the track.
Good for you, and looking forward to the feedback.
Last edited by FFaust; 10-25-2012 at 08:54 PM. Reason: deleted content by owners request
#45
GT3 player par excellence
four week out?
whew, i guess i would have sold my car by then.
