HELP! schroth install!
as always, i seem to get stymied on the first step...
i have schroth profi's and GT2 seats. the harness lap belts are anchored on the same bolt as, and beneath, the OEM lap belts, correct? should the bolt look the same on both sides?? on the outboard of each seat, there is a long bolt with both a thick, and a very thin washer. i.e. plenty of room to attach both belt ends. but on the inboard side, the receptacles are held on by a much shorter bolt. am i screwed here?? should i have gotten the long ones on both sides? otherwise, how can i attach both the OEM receptacle and the harness ends with that one stubby bolt?
thanks for any help!!
Admin
This is from the 6GT3 when running a dual belt setup:
![](https://rennlist.com/forums/attachments/996-gt2-gt3-forum/523123d1301094589-gt3-seats-belts-3p-and-6-point.jpg)
For the 7GT with folding GT buckets
Guide belt strap from the inside to the outside.
Ensure that the belt strap can run properly.
Guide seat belt mount -3- through the sports bucket seat -arrow-.
Secure seat belt mount -3- to the sports bucket seat with the fastening screw -2- , spring washer -4- , spacer sleeve -5- and washer -6-.
Tightening torque for the bolts: 50 Nm (37 ftlb.)
Press in cap -1- .
To make room for the 6p lap belts you might have to remove one of the washers 4 / 6, you need room so that the belts can pivot freely. If the inside bolt is not long enough, get the longer one.
Press in cap -1- .
