Michelin PSS .1 GT3 SWall FLEX
#46
Cracks usually appear on old tyres: the rubber looses its "plasticity", I would guess that if you track them you can't rely on normal behaviour,too much of a risk to go full out!....
#47
I just won this auction for 200 bucks!!
Now I need to mount my old rear cups inverted or source some good condition cup rears..
#50
I am reliably informed that these cracks are most likely "cosmetic" as long as you cannot see any of the underlying material/construction...
however, it is probably indicative of "old" rubber, as such it will not perform as well as it might, you should check the date of manufacture on the sides ...
