Mancation; Road America-Calabogie-Tremblant-Mosport....OH CANADA
#796
Oh, yes...by far.
#798
It also helped to switch out of 10 month old MPSCs, and not have a flat front tire
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#799
I realize I am miles slower than everyone else...but I too felt that when I started braking earlier for Canada (so could be smoother), I could be on the power sooner through the turn and surprised myself how much faster I was at the top of the hill (tracking out in the parking lot). Similar for Turn 1, braking sooner and shallower (if that's correct terminology) I could carry more rolling speed through the apex and be on the power all the way through to Turn 3. Rather than, in both instances, braking super hard and late and then having to commit 100% focus to controlling the car through the corner rather than being on the power. I noticed me being smoother let me be faster through consecutive corners...at least for me being a beginner
Yup! A lot of it has to do with where the mass of the car is moving during that transition (braking, followed by turning). if we can reduce the drama of the first transition (IE, brake more softly, thus not pitchhing the car on its nose & heavily unloading the rear tires), the second transition (lateral) works a LOT better, with huge increases in the amount of all 4 contact patches available throughout the corner, and much better suspension compliance in order to get the power down.
#801
Um.. Indeed. I braked so much too late! The exit of Canada corner was soo slippery, even when taken right. Is it always like that?
As you found out Canada Corner can be quite slippery. Late braking can be very exciting there
. It is not always like that but more often than not. It can be a really exciting track after a vintage weekend event with those cars dropping all of their various fluids. Canada is one corner I have never felt completely comfortable with. Seem to be too slow or too fast. Rarely seems to flow. 13-14 is really fun though although I liked it better when the bridge was in place (though much safer now.) Enjoy Mosport.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#803
This will make it car #8 on my list of documented limp-mode/overheat problems with the MP4-12C.
The door issues are both: unable to close and unable to open. Well known, it is being repaired by adding a door latch on all cars as part of the 25Hp upgrade package.
The overheat/limp-mode issue has not been resolved. The engine compartment temperatures are measured, and when they reach a threshold, the car enters limp mode. The Gallardo, Murcielago, and all recent Fiats have the same system. However, the MP4-12C being a Turbo car generates more heat. It is going to take a while to resolve this one, as it is extensive work to be done (Turbo jackets, insulation, additional transmission cooler, Turbo oil cooler).
Emotional decision, I would dump the Scuderia for a MP4-12C (a no options car, except paint and few carbon). Rational decision, stay away from it for a few years, or probably forever if they continue the tradition of British craftsmanship.
Second, the car did not overheat. There are bar graphs that show oil and water temp. The oil temp would go yellow after four or five laps and the water temp did the same a couple of laps later. There was apparently a little too much coolant in the car and it puked out a very small amount the first session and never again. I should have contacted the McLaren engineers right away but instead I'd just run the car until the oil went yellow and then pass through the pits or take a slower lap. When I did email the McLaren engineers (try that with Porsche) they said the yellow is set pretty low and not to worry about it on the track but to obviously watch to see if it was climbing or going red. They said if it was just tettering on yellow, which it was, it was no problem at all.
So, my impressions of the 12C. Between my GF and I we've owned a dozen Porsches and I have a lot of race miles on a 996 stock class car, a 996 cup and a 997 cup in both PCA and a few IMSA Patron so I'm still a die hard Porsche guy. Having said that, the 12C is a crazy fun car. The fit and finish are perfect and the car is rock solid. We drove it 350 miles to RA, ran a pretty easy (I can't afford to wreck it) 2:27 on Pirelli street tires, packed up and drove it home. As mentioned above the support for the car is amazing. I'm saving a text from McLaren engineering giving me suggested cold track tire pressures. Like I said, they responded immediately to my question about the oil going yellow with a bunch of questions about air temp, top speed, etc. and then got back to me in minutes with the don't worry, drive the wheels off it and get back to us on how it performs. Unfortunately I had already left the track.
It as great to see all the RS's at the track. Have fun in Mosport guys. Its the best track in NA.
Jim
#804
#806
To the mancation crowd coming to Mosport - this is exactly what pro David Empringham does going over #2 and #4 - he actually enters #2 and #4 much faster than you think is possible and carries the brakes right over and down the hill and avoids triggering ABS or unsettling the car (it is really amazing when you are in the car and see it done) - the car is extremely balanced as he does this (you feel like you are perfectly balanced on the 4 tires) - then once he gets it set (it feels almost delicate) he then has so much more grip he goes WOT way earlier than you think is possible - this was the most shocking thing to me - it was done in my car, I couldn't believe the grip the car had going down #2 - it was quite frankly unbelievable as I didn't think the car could do what it was doing - (don't try this and total your car - i'm just telling you what he did) - doing this technique basically in #2, #4 and similarly in #8 was how he did the lap 3 seconds faster than I could (and I was in the car to boot)
#807
Spec as it was for my last session on 7/10/12. For my next outing I will probably reduce the rear camber to 2-2.25 degrees and increase rear toe in to 4mm total, change sway bar settings to F-2 from FULL SOFT, R-FULL SOFT. From there, I will either increase or decrease rear compression depending on the handling. Only problem I have is finding a shop I trust up here in Chicago.
ARB FRONT- 1 from FULL SOFT
ARB REAR- FULL SOFT
Spring kit- OHLINS Spec-
FRONT 685/342
REAR 1313/456
Valving (from full stiff)-
FRONT COMPRESSION
HIGH SPEED- 23
LOW SPEED-12
FRONT REBOUND
HIGH SPEED- 23
LOW SPEED- 18
REAR COMPRESSION- 10
REAR REBOUND- 13
ARB REAR- FULL SOFT
FRONT 685/342
REAR 1313/456
FRONT COMPRESSION
HIGH SPEED- 23
LOW SPEED-12
FRONT REBOUND
HIGH SPEED- 23
LOW SPEED- 18
REAR REBOUND- 13
#808
Had to keep car out of boost by taking the car a gear higher to keep it from swapping ends
#809
#810
Intersport...specialists in rebuilding?
Best of luck with rest of trip.
Ramon
