Question on ride height
#31
1/2 tank, and put dumbbells on the driver's seat 100 lbs - 350 lbs, depending how heavy is the driver.
#32
#34
The ride height front is ground to the above measurement point off the chasis.....same with rear.
The chasis measurement points are for reference, not the same height off the ground.
I believe if you look at my car it is little to no rake
#38
102-88= 14mm
137-119=18mm
so 4 more mm of rake from factory ride height
It was first set by Orbit, then checked by Autoquest
Peter has exact same set up
137-119=18mm
#41
#42
Gotcha, you have 4mm less rake than factory setup. Good to know for when I have to switch over to my 335 RA1's regardless.
#44
#45
