Slight vibration when shifting
It doesn't happen all the time.
I've noticed as of late that I feel a light vibration when shifting into say 1st from neutral or while under light acceleration from 1st to 2nd and less so 2nd to 3rd.
It's hard to pin point exactly, but the sensation is almost like you're holding a tuning fork in your hand, just that the effect isn't nearly as direct, but I definitely feel it.
I remember it grinded once just after I started driving off first start of the day shifting from 1st to 2nd, but it might've been that I was lazy? It was a very low revs shift at around 3K... not sure if this had any effect on the vibration?
Otherwise, it drives fine per usual. I don't feel the vibration in my hand when I shift with more vigor at higher revs and speeds.
Thanks and apologies for the rather boring thread.
