2010 gt3 rear seat
2010 gt3 rear seat
Does anyone know if the rear tub still has the mounts for seat belts like the 07-08 did? If anyone has stripped a .2 gt3 photos of the mounts/ threaded bungs would be great.
the inserts on the door sides of the car (where the tequipment bar mounts) are still there but the inserts on the tunnel sides are no longer present. no pictures, but visually confirmed.
Thanks martinkm. does anyone else have pics and please specify regular gt3 or rs. So i assume the top and side seat belt are there but the tunnel for the receptle is not. Why would they change it. I sold the wife on a back seat. anyone have any ideas?
The skin is definitely very thin--buckles under weight and you'll know what I'm talking about once you try it. Sure you're not planning to put a 100-lb labrador back there, but do take that into consideration...
That the skin buckles is first hand knowledge. Strippers ain't my type so I wouldn't comment on others' posts...
I can confirm that a regular GT3 is single skin in the tunnel area. I've seen comments from folks with the 997.2 RS saying that the seat belt inserts are "all there" but the comment was made in the context of installing a harness bar which only uses the outside holes, so I suspect they are the same. There is another thread where the poster installs seat belts in a 997.1 GT3 and had to source a bracket from a Carrera that wasn't available to purchase. One wonders if the missing 'second skin' could be similarly sourced....
I would not do it.
Why would you buy a GT3 if you want a rear seat? On the back of the sport buckets there is a warning tag about the seatbacks being an injury hazard for rear seat passengers. If you want a street car with rear seats, just buy a Carrera S or a Turbo.
the warning is there simply because there are no rear seats
another 911 of the same vintage has the same "dangerous" seat backs and they have rear seats
