Pressure plate and clutch 3.8 VS 4.0
#61
Admin
Actually very little difference in daily driving. Have installed a number of LWFs in the newer cars and left the solid hub clutch. Drivers have no clue what is still there. Never an issue or complaint. As long as you do not go to a 6-4-3 paddle blade, you will get some slip and very streetable and still good on track. For real track junkies, a little better material on the full solid disc is needed.
Agreed it you don't go full out on a race clutch it's drivable.
Now after looking at this failure near the spring, (and if Peter's clutch shows the exact same failure) I think I am going to change the 3.8 PP and clutch to something better before it fails.
I was lucky before when the RSR PP failed and had no gearbox cell damage, just some scratches, risking it again seems like a bad idea.
On the other hand the 4L PP doesn't look very different.
What you can see from these pics?
#62
I screwed up on not taking pictures of the side
#63
I have not read the above.
Car will be done Tuesday $2700.
Champion really stepped up twice now. No thanks to Porsche. I think it is disgraceful.
Porsche knows they have a defective part and did not allow the dealer to put in the preceding 4. Clutch.
#65
Do you need to replace the throw out bearing as well when swapping from 3.8 to 4.0 PP and clutch?
#68
I agree with this.
When I put in a new PP for my 997mk1.gt3 I went with a non-spring version for the Friction Disk (this is what Alex at Sharkwerks sent). You would not know the difference at all - the PP is the OE unit for the 997gt3.mk1.
There is a 'tiny' increase in nose as without the spring, very slightly more vibration is transmitted - but getting rid of the springs is a better solution in my opinion.
#70
Here are the parts I had replace.....not sure what ones were needed due to damage in lieu of upgrade
997-116-013-91 Clutch Disk
997-116-027-91 Pressure Plate
944-116-080-01 Release Bearing 72mm
950-116-813-30 Clutch Guide Tube
997-116-086-90 AS Release Lever
#71
Well at least you 2 will will ready for Winter Fest with you new cheater clutch parts...LOL
#73
Just picked up the car at Champion, no invoice yet they are rightfully still arguing with Porsche.
The clutch pedal much lighter with the 4.0 PP, but I don't remember anyone saying 4.0's clutch pedals are lighter?!
Going to PBIR tonight to test the car and see if all is OK for Sebring Saturday and again PBIR for Sunday.
