Headlight Weight Reduction
In a mission to drop all possible weight (sans interior carpet) from my 997.1 GT3 RS, I've addressed all the obvious (and not so obvious) opportunities except headlights. Don't ask me why I'm doing this. ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I rarely/never use the car at night and would like to drop the 13-14 lbs. of the litronic (xenon) headlight washers/levelers. Has anyone downgraded to halogens while pulling the headlight reservoir? If so, any issues? Is there any reason why the reservoirs can't be pulled and the litronics retained (other than government regs.)? Can 13+ lbs. be saved in both scenarios?
Thanks in advance for your help.
The standard halogen headlight compared to the HID headlight are about the same weight, weight saving: 0.5 lbs that's it.
Just run an empty reservoir and save 11 lbs.
I pulled my reservoir. Not such a big job, just takes time. I will check the weight of the empty reservoir tomorrow, but as I recall it was about 2-3 lbs or so. Like NJ-GT says the weight is in the fluid and yes that could easily be 11 lbs or more.
PS- Don't forget, that is your windshield wash fluid as well. You could find yourself with a big problem street driving and no washer fluid if you hit a mud puddle.
PPS- Don't forget with an empty or pulled reservoir you will have a continous low washer fluid warning in the center display. I tried to turn it off with my Durametric but couldn't make it happen.
13-15 lbs off the left front is a lot to me, I was happy to see it go (on my trailered track car).
