FS: 07-08 GT3 and GT3RS rear brake cooling kit
- stop selling these - i got mine to fit with the RSS Arms
- all you need to do is use 2 large hose clamps - the type that you use a screw driver to turn and they tighten
- it works - i have done it on my car
- i will try and take a picture later
- you need two of these metal clamps per side
- pretty easy install
- not sure what 4 of these metal hose clamps cost - but has to be less than $20
- you no longer use the plastic piece that fits over the control arm
- the clamps go over the arm and fit though the holes that the top plastic piece teeth fit into
Paul
Paul
Paul
Paul
