997 GT2/GT3 Forum 2005-2012
Is CAN bus available aywhere under dash area?
Old 08-24-2011 | 11:47 AM
utkinpol's Avatar
utkinpol
Default Is CAN bus available aywhere under dash area?
Hi,
question is if in 997 cars CAN bus was available anywhere in the front area or is the only spot where you can tap into it (for data logger install) is under rear panel where ECU sits?
I assumed it had to be somewhere in front dash too but looked at wiring diagrams and it is not very clear to me. does anybody here have an answer?
Regards, Paul.
Old 08-24-2011 | 11:50 AM
BBMGT3's Avatar
BBMGT3
I believe in the footwell, above your clutch foot.
Old 08-24-2011 | 11:54 AM
utkinpol's Avatar
utkinpol
wonderful , will go check it out now. do you have a diagram or name of a connector there by any chance?
Old 08-24-2011 | 04:31 PM
P.J.S.'s Avatar
P.J.S.
connected my aim to the ecu on the shelf in the back... nothing up front that I know of and a wiring diagram was not avaialble to me... maybe 911slow has one
Old 08-25-2011 | 06:35 PM
Macster's Avatar
Macster
Originally Posted by utkinpol
Hi,
Regards, Paul.
The car is supposed to have an OBDII connector located very close to the driver.
Check under the dash. You'll have to get down low cause the connector may be a bit behind the curve of the bottom of the dash.
Look for a flattened D connector with 16 holes though not all will be populated with metal sockets for the pins. The connector plastic might be pink, or light purple.
Here's a link to a google search that shows a bunch of OBD2 connectors:
http://www.google.com/search?q=obd2+...2&ved=0CEAQsAQ
FWIW, the engine controller protocol might not be CAN. In some cars Porsche uses KWP2000 or ISO-9141-2 and reserves CAN for the 'comfort' bus (radio, stereo, perhaps the instrument cluster).
Auto makers were supposed to switch over to CAN in '08 but some (and this includes Porsche) received permission to postpone the move to CAN.
Sincerely,
Macster.
Old 08-25-2011 | 06:47 PM
P.J.S.'s Avatar
P.J.S.
I was told by aim that they have not written the protocol for 997 cars to use the simple obd cable to run their dash off the obd port
Old 08-26-2011 | 05:22 AM
Nordschleife's Avatar
Nordschleife
when looking for CANbus/OBD connectors to make use of, be sure that you are using a connector that is designed for regular use. Some connectors are likely to fail if used too frequently (don't ask me why, its a dumb economy that companies like Lada learned to avoid)
R+C
Old 08-26-2011 | 09:52 AM
utkinpol's Avatar
utkinpol
thanks to everybody.
i also got a picture of such connection to aim pista. apparently color code on wires is same as on back shelf. will try to get it done either this wekend or some time next week.
Quick Reply: Is CAN bus available aywhere under dash area?
