997 GT2/GT3 Forum 2005-2012
Alignment Readings
Old May 23, 2011 | 08:33 AM
CRex's Avatar
CRex
Originally Posted by almeena58
To do alignment you need to consider not the Cambers, Toe.. readings only, you need to consider the weight distribution on each wheel and to consider also doing some alignment for the Exhaust system as well. This is what the Regional manager told my local dealer to tell me the right way to do GT3 alignment. Funny, they don’t have the right equipment to do that!!!!!
Man, run for the hills!!
This dealer might have confused a corner balance with an alignment. You typically corner balance, then align. One's got to do with weight distro, the other, geometry of the contact patches. Either way, your dealer's waltzing in lala-land...
And... EXHAUST??? I surrender bro... your GT3 must've had the F-22 Raptor upgrade with the thrust-vectoring exhaust package...
Nutz as he is, he's got one thing right: PDI doesn't cover alignment. But that doesn't mean you're aligned. My 997.1 and 997.2 RS all came with a whackjob of alignments. Both understeered on a biblical scale. I was on a hunter machine within the first 200 miles in both cases!!
Old May 23, 2011 | 08:53 AM
BBMGT3's Avatar
BBMGT3
The service quality / professionalism in our part of the world borders on comical. Such is life with no competition, fragmented market, etc...
Old Oct 3, 2011 | 07:08 AM
almeena58's Avatar
almeena58
I have made an alignment at the dealer as follows:
Camber (Front:L/R): -1°29' / -1°33'
Camber (Rear:L/R): -1°31' / -1°29'
Toe (per side, F/R): 0°00' / 0°13'
Caster (Front:L/R): 8°13' / 8°03'
Now the car raised by almost 3cm front and almost 1cm rear, as they said this is the standard setup for road driving. the ground clearance from the front spoiler is 14cm far from the ground and when using lifting system is about 17cm.
the car is amazing now and much stable at high speed and the ground clearance is superb i can go most of places i was using the front lifting system now without switching it on.
the car looks to me little high compared to previous setup and when using the front lifting system the front will jump with any small rock or hole
File Type: jpg
Old Oct 3, 2011 | 08:31 AM
BBMGT3's Avatar
BBMGT3
PM me your email address, I will email you my alignment sheet, which includes corner balance, bump steer, and ride height. Its for a 997.1, and I will try to get you one from a 997.2.
In all honesty your dealer is full of $hit.
Old Oct 3, 2011 | 09:18 AM
mdrums's Avatar
mdrums
WOW, you toe is way way off!!!! You should have equal toe per side. Zero toe per side is good or at the most .5mm toe out per side. Your Camber per side is close butcould be even more dialed in.
Old Oct 3, 2011 | 09:26 AM
almeena58's Avatar
almeena58
Toe are equal in front both sides and they are equal in rear both sides
Old Oct 3, 2011 | 10:32 AM
mdrums's Avatar
mdrums
Yep my fault...I was reading your chart wrong...erace erace erace...LOL thanks!
Old Oct 3, 2011 | 11:58 AM
utkinpol's Avatar
utkinpol
was there any specific reason to set camber for higher values on right front and left rear? just curious.
also, if you measure with a ruler from ground to the outer edge of front left fender right above wheel hub - what do you get?
Old Oct 3, 2011 | 12:36 PM
Aerokitted's Avatar
Aerokitted
I had the dealer align mine and they likely took it to stock specs - felt horrible even on the street. on-center steering was vague.
had my indy shop do it again and back to feeling awesomeness. i wouldn't take it to the dealer as all they know is to do it out of a book
Old Oct 4, 2011 | 01:33 AM
almeena58's Avatar
almeena58
they said it is within the range so this difference will not make any issue and for the measurment i will check and update u
actually yes i have checked the user manual and it is exactly the same and according to the user manual they said it is recommended to use these setup in both road and track driving, my issue is just about the hight of the car it looks higher but not as the C2S or 4S with PASM, i have asked my friends have you noticed any thing to it and they said it is as before but i know my car and i am using it every single day it is higher
frankly speaking i am happey with the new highet it saves the car and it become durable as Daily driving.
Old Oct 4, 2011 | 02:01 AM
Aerokitted's Avatar
Aerokitted
post pics man it's the only way to tell
Old Oct 5, 2011 | 01:49 AM
almeena58's Avatar
almeena58
here they are
File Type: jpg
File Type: jpg
Old Oct 10, 2011 | 08:24 AM
almeena58's Avatar
almeena58
can we get some measurments to compare with mine
Old Oct 11, 2011 | 03:05 AM
CRex's Avatar
CRex
Well, how about 9 inches?
Sorry, kidding aside, the standard ride height varies from region to region. You'd rarely get two cars with the same height at four corners. Mine for example came with barely a finger's width between the top of the tire and fender.
The important thing is that your car's corner balanced (assuming your local guys are able to do that properly). My own experience is that these cars are VERY sensitive to rake changes. As little as 5mm of tilt either way can radically change the track behavior (often for the worse in my own experience...).
Once you have the corners balanced, raise or lower the four corners by the same amount to get the desired looks. Then do an alignment...
