Hans and GT2 seats
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Anyone else having problems with using a HANS with the GT2 seats? My 2007 GT3 which now has the GT2 cloth seats and Safety Devices rollbar is very uncomfortable when I use my HANS device. It pushes my head too far forward and I have to look out of the top of my glasses and helmet eyeport. Are there any shims that can be used to lay the seat back slightly to compensate for this? Or do I have the wrong HANS?
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
I have been trying the ISSAC Device now over five track days and I like it. Added plus-I now have lateral impact head/neck support without a halo seat. HANS only good for straight-on impacts.
If I can't rock thwe seat back I guess I will try the ISAAC> Will it work with the Hans anchors? Sure hope so. I will do some research online before pulling the trigger.
http://www.isaacdirect.com/
Thanks, went to their site and did the research. I may add the Isaac to the gear, although I do prefer the HANS, having actually tested it in my 944 race car, not by choice!
Thanks again.
Thanks again.
Subscribed. The HANS is definitely on my near-term purchase list and would like to know if I should be getting the 10-degree version instead...
i didn't have any issues with hans 20 pro in the gt2 buckets. i also took the foam pad out of the base of the seat. used some pillow stuffing to give the front portion a little support. now i sit 2 inches lower and have great feedback from the car.
I've got the same set-up and the same problem. I'd be curious to know if the 10° HANS makes a difference. I've spoken to a few owners who simply shimmed the front mounting under the seat rails in order to tip the seat back a bit more. That's cheap and easy, so I may try that first!
