GT2 Tires
I am on the verge of going crazy trying to get road tires.
Would it kill me if I were to down size the rears from 325/30/19 to 305/3019?
Stock Tire - 325/30R19 >Search Tires Tire 1 - 305/30R19 >Search Tires
Section Width: 12.79 in 325 mm
Section Width: 12.00 in 305 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 12 - 13 in
Rim Width Range: 10.5 - 11.5 in
Overall Diameter: 26.67 in 677.41 mm
Overall Diameter: 26.20 in 665.48 mm
Sidewall Height: 3.83 in 97.282 mm
Sidewall Height: 3.60 in 91.44 mm
Radius: 13.33 in 338.58 mm
Radius: 13.10 in 332.74 mm
Circumference: 83.78 in 2128.0 mm
Circumference: 82.30 in 2090.4 mm
Revs per Mile: 779.9
Revs per Mile: 793.8
Actual Speed: 60 mph 100 km/h
Speedometer1: 61.0 mph 101. km/h
Speedometer Difference: - Speedometer Difference: 1.782% too fast
Diameter Difference: - Diameter Difference: 1.77%
I've literally just been down this ugly road, and unfortunately the answer is, on our 12x19 wheels (my GT3RS is the same as your GT2s) the only tires you can use are the SportCups that you have now, or the Pirelli Corsa System.
Trust me when I tell ya I've tried every possible tire company and resource to answer the question.
(In-fact I wrote a complaint to Michelin this morning telling them to remove the darn GT3RS they show for the SuperSports if they dont produce it for the car, as false advertising. They did actually reply back with an "we are sorry.....blah blah blah" and they would have marketing fix it).
