Non-sport bucket and track use...
At 6'6" with the seat all the way back, I recline the seat-back, lock the seat belt by yanking on it and while holding it locked I incline the seat-back until I'm firmly wedged into the seat. It's a very secure feeling on the track locked in like this.
My main issue with this, is that my left clavicle becomes very bruised from the seat strap by the end of an event.
My secondary issue... once in a while the strap unlocks while on track, if I don't get it "bruisingly" tight.... and I then feel like I'm going to fall out of my seat.....
You need to toss the stock seats and get the factory seats with the cut-outs for the harness.
If you swap seats each time you track you will deal with airbag lights.
The factory seats with the cut-outs are comfortable to use all day and are not much harder to slide in and out of for entry/exit.
Get the seats.
Get the seats.
Also, since you have to go aftermarket for sub bars on the Sports Buckets (Brey Krause) also note that Shroth has a 4pt harness as well, although you should check on rules compliance with the event organisers you plan to attend before selecting these.
See the thread in the racing forum on 4pt belts before considering it.
If u doing 4 point harnesses make sure they say ASM. I got pegged by NASA without ASM and had to buy a new set to run that day(wasn't my gt3 but my backup car). That was awhile ago so maybe rules have changed that u need a sub belt ie 5 point. But as others suggested ^go for a trackseat 5 point and a good rollcage and HANS. Mike
1st I have heard of this, and not something visible in the car configurator ... Does it appear in the order guide?
