Help with changing out seats
I am getting ready to order a 2011 GTS Cab as a stable mate for the GT3. Having tracked the GT3 several times I can see real value in the sport buckets seats. I ordered the GT3 with regular sport seats, not the adaptive. So am thinking I will order the GTS with buckets and put them into the GT3 and vis versa. Does anyone see a problem with being able to do this? I talked to the service dept at the dealership and they said no problem. But I would like to get another opinion(s). The GTS will be a DD so I don't want or need buckets, and the GT3 will likely see more of the track. The GT3 is a 2010 if that matters.
Cheers.
Cheers.
Easy peasy any dealer should be able to do the swap in an hour or so ...
Cheers.
Cheers.
I documented it somewhere on the site and I think that it took me about 3 hours, taking my time to do it "just right" and about 20 minutes of that 3 hrs will have been fiddling with the bottom part of the harness to find the length that I needed on both seats.
Looks like you will be having the best of all worlds very soon!
^ I was suggesting that it would take a dealer around an hour to swap the seats out, not DIY.
