RECARO seat side protector for CGT/EURO CLUBSPORT seats
Since my GT3 is going to be a daily driver soon, I wanted to protect the exterior lower bolster sides of my CLUBSPORT seats so the leather doesn't get scratched up too much and worn/creased when getting in and out of the seat.
Found this RECARO seat side protector from RECARO JAPAN to extend the longevity of the seat a little.
Great product and didn't have to be BETSY ROSS and fabricate/sew my own side protection piece.
No affiliation to them, but got it from Aaron from gotuning.com.
They also carry RECARO JAPAN brackets/sliders for Porsche so if you ever get a Recaro seat from USA (SP-A, SP-G, Hans), and cant find brackets/sliders for your 911, then they have it for ya.
link to the side protectors:
http://www.gotuning.com/advanced_sea...ds=recaro+side
Here are pix of the RECARO JAPAN side protector on my seats:
Your stock leather will last thru DD use--mine looked just like new after 2 years and 15k miles.
Nice find nevertheless
Reinstall the factory 3 pt belt and take it out of the lap belt tunnel ...
If you have a strong view otherwise do please tell. It may save lives one day...
That's how mine came from the factory too--thru the tunnel. In general my practice has been to minimize the number of pivot points between the belt attachments and the body, and that would include the side of the bucket seats (if the buckles have to go outside of the tunnel, that is).
My peronal view is that routing them through the lap tunnels makes no sense as far as I can see in an accident when the belt tensioner fires the "S" formed by your thigh and the lap tunnel will not help ... But I am not an automotive engineer.
If you route the 3 pt outside if the Lap tunnel it will behave exactly like it would if your were sitting in any other seat properly
The advantage of doing this is that when you sit in the seat you wont rub the buckle on the side of the seat.
Btw I would still run the 6 pt laps thru the lap tunnel ... Just not the 3 pt .... The 6 pt thru the tunnel will give you better retention into the seat in case if an accident ... And there is no pyrotechnic tensioner active in that case
Hey Larry,
Howdy neighbor.
I ran the 3 pt seatbealt routed through the tunnels because that is how they ran them from factory as pictured with the CGT/Clubsport seats and also because of the points described by CRex.
In 2007 GT3
And In GT2RS
But with 6 point installed, people usually don't run it through the lap tunnel but leave it to the side, since as u know its usually for track duty.
Howdy neighbor.
In 2007 GT3
And In GT2RS
Admin
I cannot say why Porsche routed the 3pt through the lap tunnels on these seats ... They did not do this on the 996 recaros (and for the record f**k. iPad spell check)
The belt buckle on the 6GT3 was outside of the seat’s lap opening but at the same height as the buckle is in the 7GT3 bucket seat where the buckle is on the inside of the seat’s lap opening. My guess is that the tunnel of the 7 was a bit more close to the seat to allow them to put it outside, hence the change.
However in both 996gt3 and 997.1 / 997.2 gt3 models the 3-p or 6-p belt should be passed through the lap belt side opening according to the workshop manual. Probably for a good reason.
well I guess if the workshop manual says so ... it says so!
^ well spotted!
Never had the need for these type of bolster protectors with my CGT seats. When getting in or out, I avoid wear by pivoting over the seat, by having one hand on the steering wheel, and the other on the door cill, which allows me to support my body and clear the side bolster.
That said, these look like some of the neatest bolster protectors I’ve seen,
