Gen 2 GT3RS Geometry Query
Admin
One degree is divided into 60 minutes
Porsche uses minutes in the workshop manual.
The other way written with a decimal so with minutes when you say 1° 30' degrees that is 1.5 degrees.. these two are equal. : )
That's exactly what I was saying... U can have the same alignment in degrees but if u use different tires the toe in length will be different. U're in good hands since ur garage is giving u alignment specs in degrees.
