997 GT2/GT3 Forum 2005-2012
Cold weather track day advice
Old 12-16-2010 | 02:03 PM
daedton's Avatar
daedton
Default Cold weather track day advice
Considering taking the RS this weekend to the track. Forecast is for a high of 39 and partly sunny. Should I bag it or just make sure to take temps on the tires befor egoing hard. If so what temps should I be shooting for. I'm running MPSC's. Thanks in advance.
11 RS (coming in Feb)
07 RS
98 c2s
97 c4s
77 911s
Old 12-16-2010 | 02:58 PM
Izzone's Avatar
Izzone
I woudl run it.......just go slow and get the pressure up to proper operating temps
Old 12-16-2010 | 03:06 PM
P.J.S.'s Avatar
P.J.S.
windows down -- heat on (I like it on my feet)
know that your tires are going to take longer to heat up and adjust your driving acordingly
once heated, drop the hammer..
Old 12-16-2010 | 03:10 PM
mobonic's Avatar
mobonic
hells ya go!
Just go slow as the track will be cold and green, as the day progresses and more cars drive on the track, the better it will get.
Start out with higher temps than a warmer day like 2-5 psi more and check pressures
Old 12-16-2010 | 03:13 PM
daedton's Avatar
daedton
Exactly what I was hoping to hear. Can't wait.....anything before or after is....you all know.
11 RS
07 RS
98c2s
97c4s
77911s
Old 12-16-2010 | 03:17 PM
Izzone's Avatar
Izzone
One thing I woudl do is start the car before your warm up lap and bring the oil to temp......I like to keep my rpm real low before oil is up to temp
Old 12-16-2010 | 03:33 PM
TRAKCAR's Avatar
TRAKCAR
Go. Bring Vodka.
The colder the faster the car is, just let the tires come up to temp for an extra couple of laps.
Old 12-16-2010 | 06:28 PM
FFaust's Avatar
FFaust
Be SMOOOOTH. Just don't assume there's traction until you test it yourself.
Should be fun. Want to know what I'll be doing on the weekend
Old 12-16-2010 | 07:11 PM
mobonic's Avatar
mobonic
good point, always a good thing to do before you do your first laps:
1. Start car and idle for a while (2-5 minutes)
2. drive the car around the paddock or lot or access road to warm up the engine and transmission ( I switch from 1-2-3 and back down for 2-5 minutes).
Once you get the oil temp to 175º, let her rip!
By doing this every track day, you will extend the life of your tranny and engine!
Old 12-16-2010 | 07:16 PM
Serge944's Avatar
Serge944
Shoveling snow? Check out the freak of nature that is going to be pounding the Sierra this weekend. 10 inches of moisture - this is gonna be a big one!!
Old 12-16-2010 | 09:15 PM
FFaust's Avatar
FFaust
Thanks, I needed to be reminded.
As long as all that moisture is liquid, it'll be fine.
Old 12-16-2010 | 10:15 PM
aussie jimmy's Avatar
aussie jimmy
engine loves cold air
Old 12-16-2010 | 11:20 PM
Serge944's Avatar
Serge944
Are you kidding me? There will be epic powder days this weekend.
Old 12-16-2010 | 11:42 PM
FFaust's Avatar
FFaust
Damn you, I'm in Ontario, where the highest we've got is the Niagara Escarpment, a 300 ft ridge that runs all over the province. All the ski hills are on one side of the escarpment or the other.
Moved here from Calgary in 01. Can you say Lake Louise, Sunshine, Ferniiiiiieeee.
Old 12-16-2010 | 11:44 PM
FFaust's Avatar
FFaust
Man, I've got to find a way to move to Kalifornia
Quick Reply: Cold weather track day advice
