997 GT2/GT3 Forum 2005-2012
Reason behind the different position of 997.1 GT3 Calipers versus 997.2 GT3 Calipers
Old 01-20-2019, 03:18 PM
sin911
sin911's Avatar
Originally Posted by matt33
Position aside... are the .1 and .2 calipers identical? (with 28/30/32mm pistons)
997.2 rotors are bigger than 997.1 (380mm vs 350), but can't speak for the calipers.
Old 01-21-2019, 12:27 AM
FLT6SPD
FLT6SPD's Avatar
997.1 GT pccb is 380, 997.1 GT steel is 350.
997.2 pccb and steel is 380
Old 01-21-2019, 10:01 AM
rbahr
rbahr's Avatar
The 996 caliper is used up to 2008 for the 350mm rotor
Ray
Old 01-21-2019, 12:37 PM
sin911
sin911's Avatar
Thanks! Forgot to clear that part up lol!
Old 04-28-2023, 11:30 AM
Brian Himmelman
Brian Himmelman's Avatar
DO you know if the 997.1 GT3 RS has 350mm front rotors (steels)? Much appreciated
do you have Surface Transform carbons?
Old 04-28-2023, 12:20 PM
Hinz Motorsport
Basic Sponsor
Hinz Motorsport's Avatar
Yes, it does.
-Rick
HINZ MOTORSPORT
Race Parts & Accessories for your PORSCHE
www.HinzMotorsport.com
Call: 414-212-5679
Email: rick@hinzmotorsport.com
Brian Himmelman (04-28-2023)
Old 04-28-2023, 12:56 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,986 Likes on 1,770 Posts
997.1 RS w/PCCB:
Don't mind the missing gold nut. I'm having my E88's bolts and center nut for the fake center locks coated the same color.
997.1 Non RS with w/out PCCB:
Old 04-28-2023, 03:49 PM
Steve Theodore
Steve Theodore's Avatar
Sorta related, but can anyone who has actually done it confirm that 380mm brake rotors (only) from a 997.2 GT3 work on a 997.1 GT2 with its factory yellow caliper? The Porsche part numbers are officially different but I've been informed that it's a part number update more than a physical dimensional change. Thanks all!
Old 05-01-2023, 11:32 AM
Hinz Motorsport
Basic Sponsor
997.1 GT3/RS/GT2 with iron use 350mm front and 350mm rear discs.
997.2 GT3/RS/GT2 with iron use 380mm front and 350mm rear discs.
All 997 GT2/GT3 Models with PCCB use the same 380mm front and 350mm rear discs.
The offsets are identical. Thus, yes, if your GT2 has factory PCCB calipers you can run the front 380mm pccb or iron rotors from the .2 GT3.
As an aside, if you want to keep carbon discs on the car, I have a set of 380mm front and 362mm rear ST rotors on the shelf for the 997 GT2/3. They also offer a 392mm front, but I have those on backorder at the moment.
Steve Theodore (05-01-2023)
Old 05-01-2023, 11:47 AM
Steve Theodore
Thanks for making the time to answer my question @Hinz Motorsport , I appreciate it.
Old 05-01-2023, 11:51 AM
Hinz Motorsport
Basic Sponsor
You bet!
Quick Reply: Reason behind the different position of 997.1 GT3 Calipers versus 997.2 GT3 Calipers
