997 GT2/GT3 Forum 2005-2012
I made the switch
Old Jul 22, 2010 | 10:53 PM
johnr265's Avatar
johnr265
Default I made the switch
Moving up in this world from the 996 GT3 forum to this one. Picked up a .2 RS on Saturday. Was sorry to see the yellow car go but love the new one. I've been gaining valuable info from this site on the switch so as to have minimal downtime at the track. Thanks all and look forward to contributing. Car goes in for alignment next week, and I'm crossing my fingers that the roll bar arrives before my next event.
Old Jul 22, 2010 | 11:13 PM
DavidNR's Avatar
DavidNR
Sweet! Congrats. Look forward to seeing some on track pics.
Old Jul 22, 2010 | 11:28 PM
4porsh's Avatar
4porsh
once you get comfortable with the RS on track, would love to hear your thoughts about the two platforms and the different driving dynamics and feel.
Have fun.
Old Jul 22, 2010 | 11:42 PM
Carrera GT's Avatar
Carrera GT
Wordsmith
Reading your first sentence, I was half way to saying that the 997 GT3 is not so much "movin' on up" from the 996 GT3 (having owned both and had the rare luxury of having them both at Laguna Seca for a bit of "Goldilocks" experiment) but since your second sentence reveals you're now in the new RS, then certainly, you're in exalted machinery.
What alignment specs and why the roll bar change? (what bar specs?)
Old Jul 23, 2010 | 01:59 AM
johnr265's Avatar
johnr265
Thanks for the kind words. I had the tequipment bar in the 996 (won't fit) so am going with the DAS sport. For alignment, based on other feedback (and subject to modification by my setup guy), I will likely start with -2.5F/-2.0R, zero toe front with slight toe in in rear (maybe .12" per side), front bar full stiff, rear bar one from soft. I'll let you know if he suggests differently. To get the camber in the front without undue castor change, we will likely rotate strut and use shims (again, I'll let you know if this changes). This is for the stock MPSC tires which I'll run for now and the car will be driven frequently on the street as well (I just can't bear to let her sit for long).
Early feedback on the differences on the street are mostly on power delivery and sound. The power is impressive, the lightweight flywheel racecar fast, and the sound of the engine with the sport button on, is almost italian in tone and is sooooooo addicting. Can't test true handling until the track. Ride is really tolerable (dare I say comfortable) on the street. Easily as compliant or more so than the 996. Still working on being smooth on throttle blip when heel toeing, esp in sport mode (big adjustment from the 996 with stock flywheel). In sum, simply awesome. To me, the 996 feels like a slightly detuned race car for the street while the .2 RS feels like a race car that happens to be street legal.
Old Jul 23, 2010 | 03:20 AM
Carrera GT's Avatar
Carrera GT
Wordsmith
DAS is a good bar and fits perfectly.
For alignment, check your rear toe -- the 997 uses a LOT of rear toe-in, not a little.
I'd start at -2.0 front camber on Sport Cups. I tried -2.2 and found -1.9 to bring higher apex speeds ... given Mac struts and zero camber gain and almost zero body roll, the experience in the 997.1 RS is not directly applicable to the .2 RS. At -2.5, you'd start to bring on inside shoulder wear on the street. In any case, caster won't change.
I'd recommend getting the connectors from the dealer to build an exhaust divertor valve bypass switch (look for posts by mikymu on this ... it's easy and sonorous.)
If you ever wanted to have the 996 GT3 speak in full voice, just bypass the side cans and you have the real machine ... I've never driven a water-cooled 911 that sounded better than the 996 GT3 with the bypass. The 997.1 and 997.2 GT3's sound great outside the car, but still have a hint of "Boxster" in there. The divertor valve bypass switch goes some of the way to improving that sound, but I think you have to pull the the mufflers entirely to get to the real sound track in the .2 GT cars.
Overall, from what you've said, I'd encourage you to go ahead with the safety gear and leave the suspension bone stock for your first track day. You'll be astonished by the apex speeds and braking performance. As you note, on the street, there's no way to access what the car offers, no way to get heat in the tires and no way to take the car to 100 mph+ in a straight line, let alone at the apex of a turn! : ) Once you have a feel for the car and your own limits, then you can set to work on where you want it.
Old Jul 23, 2010 | 01:17 PM
Targa Tim's Avatar
Targa Tim
Congrats on new RS.
I love everything about it except the interior noise.
Old Jul 23, 2010 | 01:27 PM
Larry Cable's Avatar
Larry Cable
have you seen the new Carnewal "remote control" ...
http://www.youtube.com/watch?v=z1V9lW1CW-4
for $150 it could be another (albeit pricey) solution ...
