Which Schroth 6pt Belts are the best to get?
I'll be using these with the Factory Clubsport 1/2 cage and the 997 euro gt3 1-piece carbon seats.....and a Hans device! Thanks in advance.
07 GT3RS
98 C2S
97 C4S
77 911S
07 GT3RS
98 C2S
97 C4S
77 911S
They make a set for Porsches which use the standard attachment points. Works fine. With the sub belt, I had a shop drill a hole through the Porsche under seat bar and bolted it in. Woroks great.
The Prosche GT3 Profi II belts are made for your set up and come with the 2" Hans shoulder belts. I run them and would not change a thing.
FROM the HMS Site:
Porsche GT3 Cup Cars come with Schroth belts direct from the factory. If you need to replace them because of an accident, or if you’re putting the factory GT3 seat setup into another car, you’ll want these belts.
They are specific because of the lap belt attachment. They have a sewn-in bracket that fits perfectly on the factory mount. Standard belts require additional fabrication and a spacer to make them work. These are a bolt-in replacement – much easier. The sub-straps have no adjusters to fit correctly in the vehicle, and the shoulder belts are shorter to reach the works cages with minimal excess.
They are available with Standard 3” shoulders or HANS specific 2”/3” in the colors shown below. Available with Pull-Down lap belts only.
Supplied Hardware
Cam Lock Fixed Point
Anti-Sub Strap
End Fittings
Shoulder: LV7 (3" Shoulders) or LV10 (HANS Specific 2"/3" Shoulders)
Lap: Sewn-in B43A (GT3 Specific Hardware)
Subs: LV11 with B14 Snap-in Bracket Wrapped-in
Extra Hardware
1 SG23 7/16" Eyebolt
1 S3 Wavy Washer
sr 91127A-0 Hans 2-Inch Black $499.00
sr 91127A-1 Hans 2-Inch Blue $499.00
sr 91127A-2 Hans 2-Inch Red $499.00
FROM the HMS Site:
Supplied Hardware
Anti-Sub Strap
End Fittings
Extra Hardware
1 S3 Wavy Washer
I've got a GT3 harness I bought that will bolt right up. It doesn't work well with my sparco seats though. I've never installed it and it's only 2 weeks old.
It's a 3" shoulder strap that will work with Hans but the 2" is actually designed for it. I'd sell for a good price if you PM me.
