!! SOLD !!: Torque wrench Multiplier For Centerlock Wheel Nut Removal & Insallation
Hi, I have a New & Unused high quality Armstrong Model 64-832 Torque Multiplier for sale.
(63) Ft/Lbs input with your basic (1/2") drive torque wrench yields Approx (380) Ft/Lbs output onto your (3/4") drive Center lock socket, required for the 97 GT3 Centerlocks. Please see these links for more details & pictures a few posts down:
http://www.alexgs.com/product/armstr...ls-64-832.html
http://www.armstrongtools.com/advsearch.aspx?kw=64-832
$525.00 Shipped in the CONUS.
I'm in LI NY and will consider a local Pick-up.
Thanks for looking....
Product Type: Torque Multipliers
Features:
* Low Input Torque (160-225 IN/LB), (1) Can easily be applied be one person using standard 1/2" drive tools
* Planetary Gear System, (1) Provides output torque accuracy of +/-5%
* Sturdy Carrying Case, (1) Allows for convenient storage, easy transportation
* Shareable Output Drive Square is Replaceable, (1)Square drive shears at 3-10% overload torque to protect against expensive internal damage
* Built in Anti-Backlash Device/Torque Holding Ratchet, (1) Maintains the multiplier's input torque allowing the use of ratcheting drive tools
* Built in Angle of Turn Protractor, ( Displays multiplier's output angle for use on fasteners requiring a specific angle rotation after applied torque
Specifications:
Type Value
Drive Size ( 1/2 in. ) (female square, input), ( 3/4 in. ) (male square, output)
Torque Input 200 ft lb [Max]
Torque Output 1200 ft lb [Max]
Torque : Ratio 6.0 @ 1
Overall Length 14 1/8 in
Locking Type Ball
Measuring System Inch
Wt. 13 lb
Manufacturer : Armstrong Tools
Details:
Weight 12.92 lbs
Manufacturer ARMSTRONG TOOLS
MfgPartNbr 64-832
Price Unit EA
Std. Package Content 1EA
UPC 781412648324
$811.12
List Price: $1638.63.
Features:
Specifications:
Type Value
Locking Type Ball
Wt. 13 lb
Details:
Weight 12.92 lbs
MfgPartNbr 64-832
Price Unit EA
UPC 781412648324
$811.12
http://www.armstrongtools.com/ecomme...Zt5E6PRQ%3d%3d
![](http://www.armstrongtools.com/LoadImage.aspx?500tucjiexhuw=QIbmCijVuIkEfhdv4U4G0uoGv0%2bvIkR%2f1zvexbzfgU0%3d&500tucjiduw=CJnKrNLqCXuFwIiJpTeDnA%3d%3d&500tucjiexmsphuw=4B7O4qqhzTBmkcOObxrXtg%3d%3d&500tdiexhuw=oAiz1uwvvbxz5%2bzUsPUoPw%3d%3d)
Does it have a means to hold the torque arm to the wheel?
No, not that I'm aware of. The way I see them work is the end of lever arm rests against the ground and is used as the fulcrum while you hold the head assembly against the nut.
OK, that would mean it has to reverse the rotation in the gearing and create a sort of "scissor" action. I guess that works. I like the way it locks against backlash so the torque wrench can ratchet away at 65 ftlb until that nut seats.
Here are some pics of the actual piece, dollar bill shown to display compact size. Comes in a nice carry case with room for a socket when some select foam is removed.
[IMG]
[/IMG]
[IMG]
[/IMG]
![](http://i252.photobucket.com/albums/hh35/giantatom/Armstrong004.jpg)
[IMG]
[/IMG]
[IMG]
![](http://i252.photobucket.com/albums/hh35/giantatom/Armstrong001.jpg)
[IMG]
![](http://i252.photobucket.com/albums/hh35/giantatom/Armstrong002.jpg)
[IMG]
![](http://i252.photobucket.com/albums/hh35/giantatom/Armstrong005.jpg)
Appealing offer!*
Does it allow for breaking the nut free as well? I thumbed through those product pages but couldn't see anything on left-hand thread torque.
* It comes with a free dollar?!
Yup, multipliers are designed to work that way, this unit is bi-directional. Just don't exceed the units max capacity of (200) Ft/lbs input -(1200) ft/Lbs output- in either direction. NOTE: I would use a standard 1/2" breaker bar in the multiplier for nut removal. I wouldn't use a good torque wrench to break the nut free, not good for the torque wrench, doing so could drop it out of calibration. Remember, after that nut has been in place for a year or two it wouldn't surprise me if you'd need up to (600) Ft/Lbs to break it free so this model is Not overkill. ...Especially if the boys at Sears Auto Center just worked on your flat. ...*Dollar not included. **Unless you really want it.
