997 GT2/GT3 Forum 2005-2012
Why not keep the exhaust valve open
Old 01-30-2010, 11:01 PM
fun2k
fun2k's Avatar
Default Why not keep the exhaust valve open
It dosnt matter whether your in sport mode or not the exhaust noise is utterly crap,sounds like a tracktor.
Why dosnt gt3 let you keep the valves open all the time,especially in sports mode?i guess someone must have found a way to prevent this from closing at low revs,but will this have any negative effect on warrantly or reliability issues?
Old 01-30-2010, 11:05 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,640 Likes on 762 Posts
Get a sharky btpass and unplug the exhaust flap.
Old 01-30-2010, 11:13 PM
fun2k
fun2k's Avatar
love to get the sharky exhaust but i just bought the car and i want to ask the dealer if they will still honor the warranty.
without sharky exhaust can you still unplug it? and porsche must have kept it like this for reason, so there any negative affects for unpluging the exhaust?
Old 01-30-2010, 11:19 PM
roberga
roberga's Avatar
I bought mine from the GM of the dealer. They also put in a Guard LSD and LWFW.
Old 01-30-2010, 11:44 PM
TRAKCAR
TRAKCAR's Avatar
Champion porsche does not void warranty with a sharky (they put it on) I've run the car unplugged since I bought it. No problem.
Old 01-31-2010, 12:06 AM
fun2k
fun2k's Avatar
ic thanks,im guessing the sport button dosnt work after you unplug it??is the there any droning while cruising?
Old 01-31-2010, 12:15 AM
brim
brim's Avatar
guys, what is "unplugging" mean? I am guessing like other cars, there is a valve in the exhaust system that opens at a certain RPM? Is it different than just always having the sport button on? Is this a simple operation?
Old 01-31-2010, 01:20 AM
tcsracing1
tcsracing1's Avatar
porsche has it like that because DOT/emissions requirements are retarded. Realistically the gt3 can run with cats and one muffler.
Old 01-31-2010, 01:21 AM
Tim Kay
Tim Kay's Avatar
There is a weather seal plug, passenger side of motor that can be pulled - keeps the valve open. someone here may be able to provide a pic.
Old 01-31-2010, 01:23 AM
tcsracing1
tcsracing1's Avatar
sport button still effects computer...... so it is still worth using even with bi-pass.
Old 01-31-2010, 01:34 AM
tcsracing1
tcsracing1's Avatar
dont talk to dealer about it.
find a favorite porsche tuner/german car shop and get them to perform your oil changes etc..... get them to install bi-pass.
If you ever have a major possible warranty issue then first remove the bi-pass at the tuner shop and then go to the dealer.....
Old 01-31-2010, 01:53 AM
Harold
Harold's Avatar
Just wait it out.... the valves always end up spoiling on their own...and once that happens you will have them perpetually open. Yes there is more resonance with the valves open at low revs but still not excessive. Or as others have said, just pull the tube on the valve and it will be permanently open....
Old 01-31-2010, 04:44 AM
CRex
CRex's Avatar
I run the Sharkwerks bypass with the valves permanently unplugged. No codes, and you get the intoxicating sound all the time. Zero resonance whatsoever. And the burbling on overruns--what music!!
Old 01-31-2010, 05:29 AM
C.J. Ichiban
Platinum Dealership
C.J. Ichiban's Avatar
Received 2,062 Likes on 581 Posts
there have been a lot of threads on this already with pictures, but basically it's a FREE fix. you unplug the clip and they rock and roll in open mode permanently.
emissions/noise regulations prohibit a lot of engine/exhaust fun from the factory.
Old 01-31-2010, 06:22 AM
fun2k
fun2k's Avatar
Alright thanks to everyone for their input.
Quick Reply: Why not keep the exhaust valve open
