997 GT2/GT3 Forum 2005-2012
worried now about pccb's
Old 02-16-2010, 07:24 PM
  #31
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
On the MK1 GT3 and RS switching to iron was easy. In front use 996 Cup car rotors. In back use 997 Cup iron rotors. You need to use new pads but the calipers are the same so you save a lot of money. Don't know about the 2010 RS but I ordered mine with iron rotors. PCCB are not ready for prime time in my view and won't be until the cost to replace is a lot more reasonable.
Old 02-16-2010, 09:42 PM
  #32
carrering
carrering's Avatar
Originally Posted by Larry Cable
ideally if the .2 irons were a dropin I'd still get the PCCB's then exchange them for irons and put the rotors "under the matress" ... just in case!
someone has had to have been the ginnypig for this. i'm hoping this is true because i would like to order the car with pccb's and then swap the rotors out. keep the pccb's for mostly street.
Old 02-17-2010, 08:38 AM
  #33
sws1
sws1's Avatar
Are you referring to the 997.1 GT3? Or the original 996 GT3?
Old 02-23-2010, 05:38 PM
  #34
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Your other option is Porsche Motorsports p50 Greens for PCCB pads - handle tough use better than OEM.
Yes, I have them right here, fresh from PMNA -
Old 02-23-2010, 05:46 PM
  #35
Bob Rouleau
I referrred to the 996 GT2 and GT3 with PCCB.
Old 02-23-2010, 06:00 PM
  #36
Larry Cable
Larry Cable's Avatar
Received 3,630 Likes on 2,357 Posts
Yup! ... honestly it's a complete SWAG on my behalf but it seems to me that if you were designing the '10 brakes and suspension and you went from 350 to 380 up front that you would maximize reuse where possible, so all the suspension parts would be the same (not the case on the .1's as I recall for the fronts at least, different wheel carriers and of course rotor diameters) calipers (except color) hats etc ...
I'd wager that if the front wheel carriers are the same on the .2 then there is a likelyhood that the rotors will interchange ... although the calipers/rotors/hats could still differ I suppose ...
We need someone with a shop and 2 cars ... or a car and some rotors!
some simple measurements of the steels should suffice:
- rotor thickness
- hat depth/height
actually thickness might be enough since you could potentially re-use the hats
from the PCCBs if in fact the hat depth/height/offset was different between the
steels/PCCBs ... which would probably imply that the calipers were different
too ...
just some arbitrary thoughts ...
would be great if it worked on the .1's as well ...
Old 02-23-2010, 06:03 PM
  #37
Bob Rouleau
You might want to read this thread and then save your money
https://rennlist.com/forums/997-gt2-...onversion.html
Old 02-23-2010, 06:05 PM
  #38
Larry Cable
Yup seen it ... but I wonder if .2 steel rotors might be:
a) a better drop in fit
and ...
b) a bit cheaper!
Quick Reply: worried now about pccb's
