997 GT2/GT3 Forum 2005-2012
Trailer advice & specs needed!
Old 01-05-2010, 08:48 PM
mobonic
mobonic's Avatar
Great advice! Thanks.
Im going to look for a used aluminum, but they are hard to comeby on the west coast!
Old 01-05-2010, 08:57 PM
rmag
rmag's Avatar
http://forums.pelicanparts.com/porsc...r-trailer.html
Old 01-05-2010, 11:03 PM
James A
James A's Avatar
Rated tow capacity of the Cayenne with the Porsche tow package is 7700 pounds.
I have towed the trailer with an M3 in it (around 6500 pounds with the car and other miscellaneous stuff) from Houston to Atlanta and back with now issues at all. But my normal tow distances are short.
Old 01-06-2010, 12:34 AM
leif997
leif997's Avatar
Originally Posted by mkozink
I went through that exact process and ended up with my enclosed Trailex. PCA members normally get a $750.00. Call and ask for Carl Carbone. I have an added incentive since they are assembled ~60 miles from where I live in NE Ohio. The trailer is ~1850# empty and ~6200# fully loaded.
I am leaving Saturday for the PBOC Winterfest at Sebring. This is the 9th consecutive year we have attended. The rig tows like a dream but you have to remember no weight distributing hitches allowed on a Trailex aluminum trailer.
I just hope it stops snowing long enough to get me through WV without any problems
I have the same trailer and in addition to its light wt attributes; one can put two full sets of tires, a nitrogen tank and regulator, indicated tools, pit scooter,helmet/HANS and drivier's suit rack; an EZ-UP tent and folding tables and chairs and most importantly; the big beer cooler
Also; the height is such that I can push the fully loaded rig into the garage and close the door if it starts to become an eye sore.
tows like a dream and in actuallity; I must always look back to make sure the thing is still there
I really like it..
Old 01-07-2010, 03:12 PM
gomez1
gomez1's Avatar
Side question > What are the best Tie Downs that you can get for the weight of a 997?
Old 01-07-2010, 03:22 PM
P.J.S.
P.J.S.'s Avatar
google macs tie downs - they are THE best
made in Idaho
Old 01-07-2010, 03:43 PM
gomez1
gomez1's Avatar
made in Idaho
Thanks! Amazing site and products!
Old 01-07-2010, 04:35 PM
AllanJ
AllanJ's Avatar
You'll want black straps since other colors will get dirty and look like crap over time.
Also, if you want padded axle straps for through-the-wheel applications, then the 40" version works well with our wide wheels.
Cheers,
Old 01-07-2010, 04:38 PM
gomez1
gomez1's Avatar
bought this set in black.
https://www.macscustomtiedowns.com/product/262/ProPacks
they look real nice.
Old 01-07-2010, 05:50 PM
James A
James A's Avatar
I agree regarding Mac's, the VersaTie Track system with the wheel nets, excellent.
Give Mac's a call and ask for Jeremy he knows his stuff!
Old 01-07-2010, 06:25 PM
AllanJ
AllanJ's Avatar
Tough to use a wheel net on a GT3. Not much clearance for your hands to get the net in place.
Also, on a GT3 (at least the 996 GT3), the right rear Rennline chassis tie down (if one uses these) is very close to an oil line. I like the added clearance of the wire hook strap end. I have a set like Gomez just bought (with twisted hooks) and a pair of wire hooks. If the D-ring is really close to the hook up point, you might want a set of direct hook ratchet straps (no strap between the ratchet and the hook).
Tons of options to choose from.
Old 01-07-2010, 06:30 PM
Sweeper
Sweeper's Avatar
doesn't the tire ride on the track? I wouldn't want my soft slicks sitting on those tracks.
I use sub surface d-rings and tire bonnets, that way the tire sits on a flat surface FWIW
Old 01-08-2010, 03:52 PM
seefouress
seefouress's Avatar
Originally Posted by mooty
buy either feather light or trailex, i like trailex
18'
trailex are open floor
featherlight are closed. each has its forte.
d ring
Mooty, am I correct in assuming your talking about the CT-7541 model Trailex with the 75" floor width? Not sure whether our cars would fit the 70" floor width of the CT-7031 model. Both models are apparently 234" long (19.5'). Thanks.
Old 01-08-2010, 04:33 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,629 Likes on 2,314 Posts
i dont recall the model number as i ended up with a much bigger enclosed trailer. call up trailex and talk to carl. he's very familiar with porsches and will direct you to the right model.
Old 01-08-2010, 04:36 PM
AllanJ
AllanJ's Avatar
A GT3 will not fit on a small 70" deck. The tires are about 72" wide at the rear. I like the extra room of an 80" deck.
Quick Reply: Trailer advice & specs needed!
