Looking for used track 18' wheels
I think I need 18" with 9" offset 53 front and 12" offset 68 rear. I run 255 Hoosiers on front and 315 rear typically.
I posted also on the WTB section. If they are cheap I do not care about the look or scratches, but must be good quality.
I know of CCW BBS and Fikse, what else is used often? OZ?
Any suggestions or comments about the wheels you have are welcome.
I'm patiently twiddling my thumbs waiting for all the 2010 RS buyers to dump their old five lug 18" track wheels in time for the spring track season. Hurry up guys!
I have an RS coming but I can not wait that long, I jhope to have 2 sets by mid summer for you.
Someone else posted the same thing I am wondereing; What is wrong with the real cheap OZ of Tire Rack?
However, They only make one 18 x 9 offset (et43) and I think it only works for a '6GT3 and not the '7GT3 so you're stuck with an 8.5' front.
Andy
I looked at Tire Rack and the have an 18" with OEM 997 GT3 offset in a buch of colors, except silver.
They are called:
O.Z. Alleggerita HLT 1 Pc. Low Pressure Cast/ Shot Peened construction
It came up as 8.5 wide, that is fine, but I prefer 9" wide for 255 front.
Weight seems OK?
FRONT:
18x8.5, OZ PORSCHE CAP
$405
Offset: +53mm
Backspacing: 6.88"
Bolt Pattern: 5-130
Rec. Tire Size: 235/40-18
Weight: 18.0lbs.
View Important TPMS Info Est. Availability: In Stock
REAR
18x12, OZ PORSCHE CAP
$484
Offset: +68mm
Backspacing: 9.17"
Bolt Pattern: 5-130
Rec. Tire Size: 295/35-18
Weight: 22.4lbs.
They are called:
Weight seems OK?
FRONT:
$405
Offset: +53mm
Backspacing: 6.88"
Bolt Pattern: 5-130
Weight: 18.0lbs.
REAR
$484
Offset: +68mm
Backspacing: 9.17"
Bolt Pattern: 5-130
Weight: 22.4lbs.
