A few shots of the 2010 GT3 tuning on ze dyno
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Hey fellas, we're still working on the video for this but a while back we spent some time with Todd@EVOMS tuning our 2010 997GT3 and in the meantime here's a few shots![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
On the way to the dyno... we brought Kermit along for some "extra-curricular activities":
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_70.JPG)
Strapped on and ready to go:
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_02.JPG)
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_07.JPG)
Running along..
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_03.JPG)
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_04.JPG)
Checking some scores...
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_09.JPG)
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_10.JPG)
With interest...
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_12.JPG)
We made around 60+ pulls throughout the day with various configurations, and Todd made adjustments to the EVOMSit software throughout the day. We also used this time to dyno our upcoming SharkWerks 997 GT3 Track Exhaust system.
Here are the results. The top line is what the car put down with the Track exhaust and the EVOMSit software. The bottom line is the baseline.
![](http://videos.g33kd.net/2010_GT3_SharkWerks_Project_Car/2010-Porsce-GT3-EVOMSit-software-and-Sharkwerks-track-exhaust.jpg)
We were most interested in the delta, or difference after the fine tuning and exhaust swap, to see what changes were made to the car's power curve as Todd continued to tinker with the ECU.
Here's another graph, showing the result with software alone as well (in middle position):
![](http://videos.g33kd.net/2010_GT3_SharkWerks_Project_Car/2010-Porsce-GT3-EVOMSit-software-only-or-software-Sharkwerks-track-exhaust.jpg)
The tuning involves a more aggressive fuel map, timing advance optimization for specific grades of fuel, and a more responsive accelerator pedal.
A summary:
With software only, the 2010 GT3 went from 392 RWHP to 404 RWHP at the peak. The car gained about this much horsepower for most of its RPM range.
The car gained over 10 ft-lb of torque at its peak around 6600 RPM and more torque throughout the RPM range.
With the exhaust and software, the gains were higher, bringing it up to 414 RWHP at the peak (22 RWHP net gain), more torque at the peak, and a large gain in torque between 3700 and 5400 RPMs.
Video:
http://www.youtube.com/watch?v=JgKzxbQbHQM
There is more about the EVOMSit software tuning process here, and a video coming soon.
Before leaving the track (Sears Point) had to get some good gas to go![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
![](http://videos.g33kd.net/2010_SharkWerks_Porsche_997_GT3_EVOMSit_Tuning_Dyno/2010_Porsche_997_GT3_SharkWerks_EVOMSit_Tuning_Dyno_19.JPG)
Running along..
With interest...
A summary:
Video:
Percentage increases and the linear gains (across the rpm range) are just amazing, it looks like someone just drew on the curves by hand and said "wouldn't this be cool?!"
I wonder what happens if you let it spin over the (current) redline?
If those power and torque curves were stock charts, I'd say "buy!"
Has anyone got an idea on what rpm that stock engine could withstand? Is the 3.9 that much stronger or running more cooling or oiling?
It seems to me that Porsche could eventually take that engine to 10K rpm -- it looks like they've built it to make power way past 8K, as if the electronics are tailoring the power to suit the redline, not as a consequence of intake or exhaust limits. How did you arrive at the rev limit on the 3.9 kit?
I think we should all start dreaming of a 10K rpm redline (and some of us might also dream of PDK in that perfect lap ...)
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
It's a mechanically linked mustang AWD dyno and these cars (and dynos) typically cause a fuss and give eronious data with only the rear wheels spinning so it's best to do it this way. The drive-train loss and correction factor actually work out nicely on this set up and the stock pulls were converted to 435hp which is spot on.
I believe there are actual-vs-adjusted tables to compensate for ram-air effect (eg. 1 psi gain in ambient, 1 deg temperature density) but I doubt the tuner could take advantage of these since they're always dialing the car back to make it survive on the street. I imagine you full well understand the variables of fuel quality, altitude ... a hot track day or a blast through Colorado.
I think you're looking at the chart with the track exhaust, right? If so there's a small loss down low with that set up. At the track that won't be an issue. For the most part we still recommend our bypass which has no loss anywhere but doesn't save the same 58 pounds.
