Road ATL 1:373 what is quick?
#31
Always all off.
Hey, that's an interesting question!
You reminded me that because I had a flat tire and because of the sudden PSI drop I got a message that "SC was partially monitoring". So it kicks back on when you get a flat??
I only saw it once (Did I imagine it??), after the tire was remounted I did get "TPM system only partialy monitoring" because only 2/3 (randomly) out of 4 were showing PSI.
#32
Admin
Dpnt ask me i dont even have a radio on the car.
So would the nanny save the ouch moment when you forgot to heel and toe downshifting? What you think?
John
John
#33
#34
Admin
#35
I just prefer to be sure that what I feel the car is doing is real and I did try the first session and the engine held back out of the tight corners, where I prefered to just have some wheelspin. I never felt the stability control, I don't know if I can't feel it or it never came on.
#36
Your RS might be able to squeek into TTS 8.70 #'s per hp depending on Dyno and adding ballast if necessary. You would get murdered in TTU if a well prepped car showed up. The RA TTB record driver is top notch with a fully prepped E36M3. It is also 1 thing to hammer a $30k car @ RA but with a $150K vehicle the downside would really hurt.
Peter
#37
#38
Admin
Larry you tested them on the Nordschleife?
John
#40
On the dry track my best times were TC(Off)+Sport(On)+PASM(normal).
PASM(sport) was too stiff for NS, but I found that the TC effected the ability of the car to turn in, not too mention that it also increased the rear brake temps in particular ... so turning it off helped.
I did run with it on when it was wet, for no other reason than being sensible ...
#41
Admin
I tested them on NS in my '07 997.1 GT3 so it's not the current PSM on the 2010 but the CGT derived TC on the .1.
John
#42
I just wonder about a system that corrects WRs driving and what it will or wont do for me when I f*** it all up!
On the new 10's I think I would at least deactivate the TC and play with the SC to see what happens ...
maybe Jim C will let us experiment on his 10 RS this coming Sunday?
#43
wish I had my new car at the ring ... but it will stay in the garage here in SF while I embarass myself in (someone elses) E90 M3 at the ring next week!
#45
