Chip to improve throttle response?
Hi,
I just finished putting 2500+ miles on my "new to me" 08 RS. Can anyone recommend a chip/reprogramming that makes the throttle react to the pedal inputs more like it is attached?
Thanks,
Steve
Thanks,
Steve
Talk to SharkWerks; they are a board sponsor. They have a clubsport package which deletes your center muffler (you will still have 2 more!) and reflashes your ECU. This removes about 18 lbs from the rear of your RS, and the reflash is tuned for the center muffler delete. As for throttle response, the tune makes the throttle response of the sport button turned ON as the default throttle response. Then when you hit the sport button, the throttle response gets even better (probably exactly what you are looking for), but it also makes wonderful exhaust notes AND your car will make more hp and torque as icing on the cake! I think the package also comes with a high flow, washable BMC filter.
Yes the revs fly, but he is talking about the reaction of egas throttle. The SharkWerks/Evo clubsport package with the reflash does address this issue (I personally do not find it an issue, but apparently some do) and makes the Egas throttle response even better as I mentioned in my previous post.
I don´t think there is anything wrong with the throttle reaction on a GT3, which is what I have, and that should be even better on the RS due to the fly wheel.
On the other hand, I have wondered myself many times in different situations why it is that the engine suddenly takes such a long time to react to my input. It has happened to me many times when downshifting.
Over the last two years I have slowly realized that it happens only when I let the revs fall too low before going for a lower gear, or when I am downshifting at low revs, which is basically the same thing.
I realized that when I get hard on the car in the very next turn and downshift with a blip from any revs over roughly 4500, the response couldn´t be better.
If that is what you are experiencing, maybe the fix is just this simple. I don´t think we can expect any road engine to go from idle to 5000 rpm in a second.
Thanks guys and we can/do adjust the throttle maps etc... although I have to admit nobody has said the RS even in stock form is numb![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
http://www.sharkwerks.com/products.php?pid=157
A group buy sounds like a great idea! All we need is about ten of us to put in $2,500.00 each, and then have the upgrade done to my GT3. I will do testing and provide feedback for the rest of the group. It is usually difficult to find a guinea pig, but I am willing to make the sacrifice.
Is that what you meant?
Hi guys,
Thanks. I just talked to Alex at SharkWerks and it sounds like his reprogrammed ECU will do what I'm looking for.
The engine response is fine, once it starts responding. My other cars have either had throttle cables attached to carburetors, or (2000 & 2001 Boxster S) were chipped to feel like it. When you blip the throttle, the revs jump... not so this car.
Thanks, and sorry for any confusion my question may have caused.
Steve
Steve
Hi guys,
Steve
Steve
http://sharkwerks.com/porsche/996-ca...e-and-ruf.html
For any of you guys needing a DIY on ECU removal: http://sharkwerks.com/porsche/techni...2-and-gt3.html
Is that what you meant?![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
And let me know when you have the part numbers for the new suspension parts. We now know the factory didn't change the chassis or the body, so the control arms are a bolt-on. And the gearbox marketing is just a different cog in 6th ... that's just inexplicable marketing nonsense. I guess when Porsche was a few billion Euros in debt (dangerously overextended from failed attempts to buy VW) and about to miss their interest payment, it was understandably hard for R&D to get funding to test a bespoke close-ratio box. So here we are looking at the last actual Porsche built by Porsche as a private, family-owned company. The next RS is a VW. Simple as that. Maybe I should buy the last ever Porsche RS ... no doubt the next "VW" RS will have an Audi steering wheel ... wait ... the GT3 and RS already have an ugly steering wheel ...
