New GT3 Brakes vs. Current GT3
1 Post
I just got my new GT3 brochure, which says that "the new two-piece brake discs have a larger diameter, now measuring 380 mm at the front and 350 mm at the rear. The combination of a cast iron disc with aluminum bell provides a further reduction in both overall weight and the unsprung, rotating masses".
My question: will these discs fit the current 997 GT3? If this is the case, then it would be a quick and easy upgrade, no?
I just replaced all four brake discs after 40,000 km (25,000 miles). Rears were still original but it is now my third set of fronts!
