wevo engine mount pics
- slowly putting together my next project pieces
- the project is to bring the car as close as possibly to a better track car while still keeping it fun to drive on a weekend without rattles
- i decided to go with the softer of the two polymers (black compound)
The complete list of my next mods includes:
- rear strut monoballs,
- lower control monoballs
- solid rear thrust arm bushings
- rear toe arms
For now, I will not be doing any of the control arms with exposed metal ball joints as from previous experience they rattle (maybe i had a bad batch but i know others that have experienced this as well) - I do know there are rubber linings that can cover the metal ball joints i just don't know if they really work
Anyways, pics of wevo engine mounts
paul
![](http://i66.photobucket.com/albums/h276/pauloneil1969/wevo_mounts_2.jpg)
- rear toe arms
paul
![](http://i66.photobucket.com/albums/h276/pauloneil1969/wevo_mounts_1.jpg)
Hey Paul, do you find that your strut tops make a bit of noise on our bombed out streets? Mine sound like the top bearing has some play, although there is zero slop in the steering or any other motion.
It's like a rattling noise. Dealership says it's normal because of the metal instead of rubber and I do recall my racecar making a ton of noise from the strut top, but wanted to get other opinions on it.
That is nothing compared to rattling metal ball joint control arms
I can live with the very occasional jolt
Paul
My 996 GT3 had full monoballs and zero noises. It depends on the quality of the parts, and particularly for the rear upper strut mounts, whether you put both top/bottom bushings and they have no play with the strut.
Paul, do you know if Wevo has the transmission mount as well?
- I.e. the engine deflection of 1.5cm from side to side is "undesirerable"
- the new mounts reduce this by 90%
- I think the wevos will do this for far cheaper (hopefully still streetable)
- for me to go faster with the car I'm looking for more predictability from the rear of the car - ie I want less wiggle on certain corners
- we shall see if this works in combination with the other parts I have mentioned
Hope that helps
Paul
Paul
