Christophorus quote – Porsche not race tested anymore...
I received the latest Christophorus issue yesterday. Check out page 40 with the following quote under the 961 article; “There is an unwritten law in the early days at Porsche: anything that goes into production first has to pass a trail by fire in racing”.
I wonder when the early days ended. Not that this is an unknown phenomenon but I guess this is an admission that race testing is not needed anymore. I wonder how this will play out when they change the GT1 block on a future generation GT3. I’d say this isn’t the smartest marketing admission from their marketing magazine...
I can't think of another car in the sub $100k category that is as racetrack capable as the new generation 911's. I thrashed a 997 PDK around a test track, did drag-race launches again and again and it ran like a clock. I did 12 track days in the GT3 last year and didn't even need to add oil. What more do people want??
I agree with both posts but the early days may not have ended for sure. the 997.2 has the GT1 block in it.
First I like that the GT1 block is in our cars because of it's racing heritage, it may leak and it may smoke sometimes but it's built like a tank. Obviously the 997.2 engines did not meet the specifications required by GT3 (GT2 and Turbo) owners or else every race team in the field would be jumping on the extra power because quite honestly in ALMS they are under powered and could use some help.
You can't beat even a standard 997s for reliability and performance. Yes a the Z06 and GT-R are both faster for less, but my GT3 has over 6000 true track miles on it (don't ask for my VIN for when I sell it) and the car is perfect and has always been driven home 50-150 miles from each track event moments after the last run session. Hitler says you can only launch a GT-R 5 times and then you have to spend 20k which makes it a 100k car. The Z06 is ok, but the best part about it is that when it breaks there are 20 mechanics that can work on that engine within yelling distance for when it leaves you stranded.
Talk about more expensive cars, Ferrari, Aston and Lambo are not well known for their longevity on the track, I've seen them all go home on trailers (one guy 3 separate times.. it was sad)
That aside, rumor has it that you get a free cat (er, *****) with every std 911 purchase.
Meow.
[QUOTE=Brian S;6330307]I agree with both posts but the early days may not have ended for sure. the 997.2 has the GT1 block in it.
Stock Porsche's have earned a great reputation as a "track car". It seems their engines are able to handle reasonable increases in hp. without causing a lot of reliability problems.
The problem with Z06's (both the C-5 & C-6) begin when the owner starts down the slippery slope of modding the engines. It's almost a direct ratio... the more you mod... the greater the reduction in reliability.
The weak link with the Vettes have been the brakes... which you can address with improved rotors & pads, or go to a Big Brake Package.
Nissan's GT-R is showing early signs of major problems... if you push it into a "track car".
I'll assume that you're referring the the GT3? The regular ol' water-cooled carrera -- since '98 -- has been steadily decontented to the point where even the LSD is now an option. (And of course the Metzger engine is now history in said models as well -- it's much cheaper of course).
Meow.
Meow.
pete
