Rear Brake replacment- Wires
Ok, I am in the process of replacing the rear pads. as suggested it the "Brake maintenance tread" below. everything when well, but those dam little wires were a bitch. I got them back in but a pain. Question. at some point to you have to replace that electrical hardware. as I roughed them up a bit in the process. Are then necessary to keep in. and lastly as to that spring assembly do you have to replace that as some point it looked good to me so far.
let me know what you guys do regarding the wires. Frank.
there is a sensor on the end of those wires that clips into the pad....if you got the wires loose from the sensor chances are the sensor is not working....they can be replaced...when I purchased replacement oem pccb pads they came with the pads...(4) connector, wire and 2 new sensors each...part number is 99661234700...most guys change their pads long before they will see a warning light so some just tape the wires up out of the way...the ceramic disc helps with brake squeal...if you break one you can leave it out but you will have more noise...
oops..sorry don't have 997 number...might be the same part tho...
