Help with BK 996 GT3 side mounts
Hi All,
Has anyone else who has installed 996 GT3 seats in their car with the
BK 9078-9 side mounts and 9004/3 belt clips also retained their factory
3 pt belts?
If so I would be very greatful if you could post pictures or instructions on how
you mounted the factory buckle on the transmission tunnel side and also the
belt clip and factory 3-pt belt on the "door" side?
- Larry
3 pt belts?
- Larry
I have. do you have the manual rails already? I had to ue 996 gt3 rails to fit the brey krause brackets unless they have designed a new bracket for the 997. I still can use my 3 point buckle because brey krause has an adapter that allows the 3 point to stiil be used. i'm pretty sure they have an instruction sheet or if you call can give you directions. if you want me to take a photo, let me know.
I was able to maintain my 3 point with the brey krause bracket. i did it 3 months ago and i recall them giving me instructions to us e the 3 point and the adapter at the same time on the tunnel side. One thing is you need the manual sliders but when I did it i had to use pp6 manual sliders . the 997 sliders didn't fit the brey krause brackets. if you want photos let me know
