Running wire from trunk through firewall
I bought a traqmate and would prefer to install the accelerometer on the floor of the trunk and run the wire through the firewall into the passenger compartment. Is there an accessible opening that a wire can be passed through? or does it require drilling?
when runing my gps antenna, i didnt find any holes and i didnt want to drill any new holes. what i did was notch a piece of the main rubber gromet which goes from the inside of the car to the firewall/trunk compartment. its a small notch to let the gps antenna go through without applying to much pressure against the metal hole.
