rattling & vibrating sound
any one have any idea what this noise could be.right rear at first i thought the after market muffler thatis a little loose but i don't think so,just a little sqeeky .at speed 60-70 nothing i here it every few minutes when driving 25-35 mph .the next thing i noticed was that when rattling and i push in the clutch it stops.i just made an appt. to bring to dealer on wed.
thanks
thanks
the 996 tt has an issue with the power steering pump/clutch accumulator that causes a whining noise within the engine compartment. the noise disappears when the clutch is depressed. do not know if this condition occurs with the 997's, but sounds like it. definately take it to dealer and have it checked out.
My struts have been replaced for causing squeaks from the front of the car over inclines and some bumps in the road. One of my friends has had his replaced 3 times now. You can hear it more with the windows open at slow speed.
My door also makes a creaking type of noise, I believe they can tighten it sometime if I took the car in. You can hear this one mostly at 70+ windows up.
My sunroof makes a dull creaking sound over some types of speed bumps..
Hope some of this narrows it down a bit or at least eliminates some possibilities.
